IFS lift questions.
Originally Posted by 881stGenRunner
sooo how about the all-pro 3" rear super-flex springs in the rear. Give me a hand for wut to do in the front. Man i appreciate how patient and helpful u are being to me. U dont know how grateful i am.
3 inch rear springs will give you about 1-2 inches of lift. first gen runners have a whole lot of butt sag. I have 3 inch springs with long shackels, and it sits level with bj spacers.
BJ spacers will start to destory steering.
#25
Torsion bars don't have anything to do with it. You really only need to upgrade your t-bars if you are carrying a heavy winch & bumper. You can buy heavier torsion bars but it will still have the same amount of travel as the stock t-bars when you crank them up. The only difference you will notice is the stock ones are a smoother ride.
I know nothing about the all-pro springs. Do a search and I am sure yo uwill find something though.
#27
#28
No, the set up is not good. Its about the best you can do for a lift with the ifs. I made that comment becasue a comment was made that a good flexy back was compensation for a no flex front. This is as good as it gets.
I wanted to run 33's, for ground clearance. I got BJ spacers, 3 inch springs, made my own shackles. I threw gears, locker, and limited slip at it. It is tearing itself apart. I also abuse it, so if you take it easy, you'll be fine.
It gets tippy. I don't notice it except when i'm leaning hard. It gets tippy.
The advantage of this set up: cost
I run 33x12.50's.
I have BJ spacers, shocks, and rear springs.
Total cost of the lift was under 500 bucks. I threw torsion bars at it later for extra weight up front, but it rode the same with the stockers.
I run 33x12.50's.
#30
The idler arm has failed. Tierod has failed. Steering stabalizer has come apart. Not much else left to go wrong.
Here's what the set up looks like.
#31
If you want your idler to be happy with BJ spacers, I suggest cranking in little to no lift. The angles that the steering arms run at when lift is cranked in is not very healthy. I believe that is what causes the steering failures associated with IFS. My LT kit keeps the arms pretty parallel to the ground and I have not had any issue with steering.
#36
the rear is only about 1/4 to 1/2 inch higher. The picture is decieving. Parked in a level lot, it is barely noticeable. Keep in mind that i have longer than stock shackles. A 3 inch spring with stock shackles will not sit as high.
#37
BJ Spacers + Low profile compression bumpstops are a good increase in IFS manners...
Pics from this weekend. Front wheel isn't fully extended yet.
David
David
