Downey Manual Hub Conversion
Anyone have expeience with Downey's conversion for Tacos?
http://www.downeyoff-road.com/Chassi...riveTrain.html
It's about $400 cheaper than the other one, can't think of the name of the company, since it reuses parts from the ADD setup.
I would be interested in seeing the success rate of pressing the ADD hubs out without damaging the wheel bearings.
Thats really the only catch with the kit that I see.
Originally Posted by Darx
Anyone have experience with Downey's conversion for Tacos?
I have been calling Downey for weeks about it and they give me a different answer every time. I have tried to get the catalog or just the instrcutions so I can see what is involved, still don't have either. One guy even told me that kit has been discontinued, which cannot be true. Everyone else there I have talked to has said they are waiting for the kits to come in - 30 days - for over a month now. Hope to get more info soon...
That's what I thought, but the description says you can re-use your wheel bearings
So, what we're saying here is that Offroad Solutions is currently the best bet for the conversion?
You can also do it with Junk Yard parts as well.
http://fastq.com/~sschaefer/junk_yard_manual_hubs.html
That's what I did...
Originally Posted by DeathCougar
PM me if you want to get some parts, i work in a Toyota wrecking yard and we got a taco in with only 35k on the odometer that would work for a swap. Ill hook ya up!
They look like these...
I actually have a set of hubcaps that fit over the manual hubs, but those with the hole in them are nice too. I'll have to post a picture of them, they bulge out further than the stock ADD caps.
I will probably just end up cutting the centers out of my original ones. Thats basically what these are anyways. Nobody seems to have them and I'm not paying $20 ea from the dealer for them.
I'm not sure which vehicle they came off of, but I don't mind having to remove the cap to make the selection, since they'll give them a bit more protection from the elements.
Jim, I took DeathCougar up on his offer and from what you explained, I'll be able to make them work with my ABS system.
Schaefer has a write up on his site.
maybe I'm not getting something here, but couldn't you just get the complete taco knuckle from upper ball joint to the 4 bolts on the lower ball joint and also get the manual hub axles and just swap it out, you wouldn't have to do any press work then, and just lock your ADD in all of the time of course most of the tacos don't have ABS with manual hubs, but the spot on the knuckle is there for the sensor, just needs to be drilled out, which if you had a drill press wouldn't be too hard, drill the main hole, drill a smaller hole, tap it and you're done. i hope im not too wrong
