Cross member foul ups.
Old 08-22-2015, 10:13 AM
skypilot's Avatar
1988 4runner. Am I missing something? Have a turbo R150 w/ chain drive xfer case. I'm 4 inches too far forward on a 3vze cross member. Gear shift levers line up right, engine is just too far forward to really work right. It looks to be all in the cross member pushing it twards the front by about 4 inches. I have area real 22re truck i'm comparing it to. Aside from the motor mounts on the frame being different I'm still off on the shifters.
Hoping someone out there has converted 3vze to 22R and tell me what I'm missing.
I do have an R154 & rf1a sitting on the floor. perhaps that and a crossmember will solve it.
Old 08-23-2015, 12:25 AM
wyoming9's Avatar
Red face
Going form a 3.0 to a 22R series engine the crossmember and the location of the motor mounts on the frame are different
You have every thing more or less in place ??
With things being to far front .
Get the engine bolted to the motor mounts
Modify the cross member so it works
Build a new one if need be.
Now when I did my 3.4 swap I needed to cut a bigger hole in the trans tunnel.
If your really stuck your not that far away I will be glad to help with anything I can.
Old 08-23-2015, 12:33 AM
Fossilized
Staff
dropzone's Avatar
The R150 in not the Turbo Transmisison.
The R151F is the turbo transmission.
I was under the impression the R154 was a 2WD transmisison
Old 08-23-2015, 04:06 AM
wyoming9's Avatar
Red face
Dropzone is correct .
I have both those Transmissions worse case I could measure
I also have a w56 and transfer case behind a 22re still in the parts truck
Old 08-23-2015, 02:31 PM
skypilot's Avatar
Here are some pics. I'm thinking the W56 has the shift at the front to make up the room.
Old 08-25-2015, 01:09 PM
wyoming9's Avatar
Red face
With the way that sits now would you be able to get the fan on and the radiator in??
I know the cross member for the 22re engines is different .
What about the front driveshaft will it be to short??
dzldust
7
10-06-2015 05:39 AM
voiddweller
10-02-2015 07:47 AM
Quick Reply: Cross member foul ups.
