Buying a WINCH
Originally Posted by rngrchad
the weight in my opinion would be one of the biggest pluses because I'm runnig ifs, and my coils don't like much stress on them. It is significantly lighter, is it not?
Does it matter when the winch itself weighs 90lbs plus the bumper/cradle it sits in? I dunno Grasshoppaa No IFS to worry about
Chad,
Doood...you need to check with me and Vince before makin' a huge purchase like that. I'm expecting a new WARN Comp winch in the near future and my 8K Warn will be up for grabs.
Screw MM. Yes, you can pull all day with a hydro unit but it will take all day to pull too
Go Warn or Go Home. Flat out.
Got your message last night Nice Sig BTW! Friggin' stellar.
I always laugh at posts about winches, everybody and there mother says how you have to go with Warn, yet they have never owned anything else. I believe that Warn is a slightly better built winch and is quicker, but unless the winch is going to be used every week I don't see the need to dish out almost $300 more. I have never heard anybody talk about their MM crapping out. Basically if you are stuck bad enough to need a winch do you really care if it takes an extra minute to get you out? If so definately get a Warn.
#25
Synthetic line is much safer in the event of a break since it is lighter and can't cause the same damage. It's much easier to handle when using snatch blocks or dragging it around. Although it is more vulnerable to heat, UV, and abrasion damage though. Not sure if it can happen with wire, but synthetic can get wrapped up onto itself when spooling in under no load, this can be a hassle to untangle.
Let's not forget it look so much cooler!
#26
Yea, the synthetic line is a lot lighter than the steel line. I think that weight matters a lot. The heavier your rig the bigger the possibility of breaking stuff, unless you upgrade everything to heavy duty. If I can save 20 pounds by going to a synthetic line then I'm more than happy to do it.
#27
I have heard stories of MMs and knock off's failing...plus I've been in situations where yes I believe it does make a different how fast and strong the winch pulls, especially when your truck is on the verge of rolling off a waterfall..ledge, etc.
Get cheaper shocks or tires, but dont go cheap on a winch, it just may save your day. just my opinion.
#28
It is all just a matter of what your preferences are. I think that your shocks and tires for example are two of the most important parts on a vehicle and shouldn't be skimpped on. You are using your tires and shocks every time your vehicle moves on or off road. If you have crappy tires, you will definately need a winch.
#29
#30
Yes, I've only owned WARN and that's because I've wheeled with guys who have had MM just to save some coin. Although I've not had any first hand experiences with the electric MM I would be more leary of them because they are new and MM got it's reputation from hydro so why switch?
If you say the weight between syn and cable matters than so would the line speed of the winch for many small, but important reasons. It's all a matter of preference like you said.
justdifferentials
09-05-2015 06:52 PM
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
09-03-2015 09:01 PM
