ARB locker Solenoid leak
I need some wisdom from you ARB fans!
The solenoid seems to be leaking out the vent when the compressor is on. If there is air in the tank, it bleeds. (I've tried a new solenoid, same result)
If I turn on the locker, it switches and pressurizes the line like it should, but when I turn off the locker, it just bleeds out the solenoid vent to zero pressure. It always just released the line pressure but didn't bleed everything.
I've tried it with the solenoid switch unplugged electrically, and it makes no difference! Trying to go 'wheeling today!
Thanks in advance for any help/pointing out any stupidity...
06-01-2021 01:51 PM
coffey50
07-28-2015 10:55 AM
