4cyl diff vs. high pinion diff - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Sign in using an external account
Register Forgot Password?
SPONSORED BY:
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 10-30-2008, 09:01 AM   #1 (permalink)
Personal Sales Rating: (0)
88toypickup's Avatar
I recently bought a 1985 axle and am planning on doing a swap sometime in the next year (hopefully). I am on a tight budget and was wondering if anybody could help me out. My question is will a 4cyl differential hold up to an 36" tires and a locker with 5.29 gears and a pretty much stock 22re? I don't want to spend the money on a high pinion and I already have a 4cyl third. I could put 5.29s in the 4cyl I already have and run the 36" Iroks I already have, but I want to do thing right the first time. I would rather save up for a high pinion then have my 4cyl break, but if the 4cyl will hold up, I would rather just keep it. Oh, and the same goes for the rear, 4cyl or v6?
__________________
1988 Pickup 4x4, 33x12.5 BFG All Terrains, 1.5" AAL, 1.5" ball joint spacers, OME torsion bars, 4.88 gears, rear true trac and front aussie locker.
88toypickup is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 10-30-2008, 09:56 AM   #2 (permalink)
Cargun's Avatar
4cyl 3rds will be fine as long as you have a fairly smooth driving style. On a stock front axle, the birfields, axle shafts, and probably even the hub studs will let go before the 3rd if setup right.
I ran a 4cyl 3rd with lockright for 1+ years in the back of my 4runner before swapping it into the front of my wheeling rig 3 years ago with 36" Iroks, 4.7:1 t-case, and V6 engine. It's still holding up fine.
If you ever start blining your rig out with a set of aftermarket birfs, axle shafts, hub studs, etc., the stouter 3rd is a good addition to that package.
__________________
I own 11 vehicles... 10 of which are ongoing projects. I need to sell some stuff so I can turn the 11th into a project.
Let me know if you're in need of a Yota transfer case, solid front axle, 22R motor, or rear axleshafts. I promise all proceeds will be directed back into the local 4x4 economy (Ok... Marlin may get some of the money) .
Cargun is offline
Old 10-30-2008, 10:12 AM   #3 (permalink)
netwt12's Avatar
the 4cyl will be fine. you'll blow a stock birf before you blow a diff anyway.
__________________
1985 4Runner exo, dual cases, 4D mtr's etc.
2002 Tundra SR5.
2008 Camry LE.
netwt12 is offline
Old 10-30-2008, 10:20 AM   #4 (permalink)
Certified Goat Herder
Personal Sales Rating: (10)
Staff
waskillywabbit's Avatar
WabFab
4 cyl will be fine. Buy Longfields.
waskillywabbit is offline
Old 10-30-2008, 11:11 AM   #5 (permalink)
tc
tc's Avatar
Same as above.
The difference in strength between the 4cyl and V6/turbo diffs is real, but pretty small.
High pinion will be ~30% stronger in the front and have better clearance than the low pinion "normal" diff. I would say these differences are hugely significant, but are probably not necessary if you're not hard on parts. If you ARE a "breaker", then you might want to look into it.
I can tell you Molly's diff with 5.71's has been stronger than the manual hubs and both stock Birfs!
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 10-30-2008, 11:50 AM   #6 (permalink)
Blizzard's Avatar
Send a message via MSN to Blizzard
HP diffs are great when you have single T-Case.
Mine is from a Toyota LJ-70 (You don't have those in the States eh?) but now I've bought a 80 Series LC one with E-Locker
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler Auto – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35's, FR&RR E-Lockers and too many things more to write...
Blizzard is offline
Old 10-30-2008, 11:55 AM   #7 (permalink)
1styota4X4's Avatar
not trying to be dumb...but what is the difference between a high pinion front and a standard front? I thought they were the same
__________________
1987 Corolla GTS daily/drift toy
1985 lifted locked dual cases Marlin crawler tube bumpers and sliders, hi-steer with ram assist, sitting in garage 5:29 arbs frt and rear, 35"km2s, dirty 30 frt axles & New trail gear 4in lift.
1985 4runner 4x4 Sold
1983 Hilux 4X4 Sold
1995 4runner 4x4 Sold
1styota4X4 is offline
Old 10-30-2008, 12:37 PM   #8 (permalink)
tc
tc's Avatar
Ummm ... a high pinion has a high pinion.
Instead of the pinion being BELOW the centerline of the ring gear, it's ABOVE the centerline. Obviously, this helps with ground clearance, but only by an inch or two. In FRONT applications, this changes the setup from being on the coast side of the gears to the drive side, which are approx 30% stronger.
3rd gen 4Runners and Tacomas have high pinion fronts, the older trucks had low pinion. The desirable option is the high pinion 8" elocker out of 80 series landcruisers
__________________
tc is offline
Old 10-30-2008, 12:41 PM   #9 (permalink)
ryantowry_81's Avatar
but note these are IFS trucks and are not the same hipinion that can be used in the minitruck strait axle, the one that fits is out of the 80 series landcruiser.
__________________
the "Turtle":
now the mutant turtle.....
84 ex cab
63" chevies
Rears Up Front
Square Drive Shaft
d60f 14 bolt rear welded both with 5.38's
home brew hi steer
42x15-15 TSL's
TBI 4.3 V-6
pretty much stock!!!
Denali offroad club:
http://www.denalioffroadclub.com/for...orum/index.php
ryantowry_81 is offline
Old 10-30-2008, 10:19 PM   #10 (permalink)
OK I am learning something here.. can I ask some questions??
What are Birfs?
What are longfields?
When switching from 4.10 with a 41 tooth ring gear and 10 tooth pinion to 4.56 with 41 tooth ring gear and 9 tooth pinion can I just change the pinion and reuse everything else?
What is the difference in the 4 pinion and 2 pinion toyota diffs and the 4 and 2 pinion diffs with LSD (I assume means limited slip differential) and can the LSD be used in place of a locker? ( am barely familiar with diffs, my concept of them comes in three flavors, open, posi trac from the muscle car era where they are always locked but have clutches, and "locking" Chevy diffs I have used that lock after you spin em at a high enough RPM.) Does any of this apply in setting up my new diffs? I am asking because I am considering the purchase of a so called limited slip differential and regearing it as my rear instead of the open turbo rear I have now.
Thanks!
__________________
Kristopher Erik Hoopes
99 Landcruiser Desert Bronze w/factory flares.
00 Lexus LX470 Forest Green
khoopes is offline
Old 10-31-2008, 09:30 AM   #11 (permalink)
Bump. Am I a thread killer?
__________________
khoopes is offline
Old 10-31-2008, 09:39 AM   #12 (permalink)
netwt12's Avatar
"can I just change the pinion and reuse everything else?"
no the ring and pinion come as a matched set.
birfield is the name of the outer axle. instead of having a u-joint so the wheels can be turned like a traditional dana axle the toyota axle has a birfield which has a cage with ball bearings that allow the outer shaft to pivot. longfields are a type of aftermarket chromolly axle that have more strength than stock dana 60 axles. they also have a lifetime warranty when combined with their hub gears.
http://www.longfieldsuperaxles.com/
__________________
2002 Tundra SR5.
2008 Camry LE.
netwt12 is offline
Old 10-31-2008, 10:45 AM   #13 (permalink)
Ha, OK, I am getting the picture a little. Since I have an IFS I was a little confused... hope someone can answer my other questions about the toyota diffs and lockers/lsd..
__________________
khoopes is offline
Old 10-31-2008, 11:02 AM   #14 (permalink)
Quote:
As for LSD they really dont do much for serious wheeling because they dont give you a positive lock up. it will work for a little extra traction in mud and snow but useless on rocks and any crawling.
__________________
the "Turtle":
84 ex cab
63" chevies
Rears Up Front
Square Drive Shaft
home brew hi steer
42x15-15 TSL's
TBI 4.3 V-6
Old 10-31-2008, 11:36 AM   #15 (permalink)
tc
tc's Avatar
http://auto.howstuffworks.com/differential.htm
4 pinion has 4 spider gears
2 pinion has 2 spider gears
__________________
tc is offline
Old 11-10-2008, 09:22 AM   #16 (permalink)
OK so now I have a used ring and pinion for both my front and rear diffs in 4.56, but my respected mechanic (dad) says he would never reuse a ring and pinion in a different differential. How about you folks??
__________________
khoopes is offline
Old 11-10-2008, 09:34 AM   #17 (permalink)
muddpigg's Avatar
Hi pinion uses the same guts as a V-6 dif, the gears are reverse cut. So are stonger when run in the front since the are run on the drive side (high pinion) as opposed to the coast side of a 4cyl 8" dif. Also better ground clearance and better DL angles.
Might want to search facts here and on pirate all this has been reveiwed many times
But since this is YT and we are kinder and gentler than the other sites, I'll do the searchin for you and save you the effort. http://home.4x4wire.com/erik/diffs/ there's much more information out there.
__________________
Parts I have to trade or sale:
Stock Alternator
Steering stablizer X2:
one used bought from Downey was on IFS
one new bought from Allpro for SAS w/ high steer
Parts I'm looking for:
Whatcha got?
muddpigg is offline
Old 11-10-2008, 09:40 AM   #18 (permalink)
muddpigg's Avatar
Birfeilds will probably be your weakest link. My buddy runs older style Longfeilds (roughly x3 stronger than stock) on 37" without issue but he relies more on technique and gears. Another buddy ran 35" on stock birfeilds and drove buy skinny pedal always broke birfields like constantly, stent more on stock birfields than I paid for a used set of Longfields.
__________________
Stock Alternator
Whatcha got?
muddpigg is offline
Old 11-10-2008, 10:04 AM   #19 (permalink)
tc
tc's Avatar
Absolutely no problem reusing them IMHO, but why not just get the diffs they were in and not have to do the gear setup again?
__________________
tc is offline
Old 09-16-2009, 10:11 AM   #20 (permalink)
Windsor's Avatar
I apologize for digging up a nearly year-old thread, but I have to ask...
Why the *bleep* are they called "2 pinion" and "4 pinion" when the differential always only has one pinion?
Why can't they just say "2 spider gears" or "4 spider gears"?
edit: nevermind. "pinion gears" are simply small gears that talk to a "ring gear". bleh.
__________________
'87 T4R Deluxe, mall crawler
every non-SR5 option installed (sans AT), as well as:
* Cruise Control (dealer installed)
* Michelin LTX A/T2 31s on 1st-gen alloy rims
* SmittyBilt granny step bar
* SR5 Instrument Cluster
Windsor is offline
Old 11-01-2011, 12:32 PM   #21 (permalink)
Dazed & Confused
Personal Sales Rating: (2)
Staff
dropzone's Avatar
Quote:
Originally Posted by toyotateen161712 View Post
my dad ran 38s in his 22r on 4.10 gears and never broke a thing and put that truck through hell
Must not have been a hellish hell, I have grenaded 4.10's on 33's...
And nice two year old thread bump..
dropzone is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
1985, 29, 30, 4runner, cyl, diff, differential, drive, front, gears, high, low, pinion, rear, sale, set, shaft, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
will a front V6 diff fit a front 4cyl diff? jjrgr21 86-95 Trucks & 4Runners 17 05-19-2008 01:16 AM
4.88 r&p for Toyota High Pinion diff SoCalWheeler71 The Classifieds GraveYard 3 05-09-2008 07:53 AM
4cyl spool in v6 diff? deserttoy84 General Vehicle Related Topics (Non Year Related) 1 04-18-2008 09:27 PM
IFS Diff Swap - Will 97 4runner V6 diff fit in 99 Tacoma 4cyl? transalper 95.5-2004 Tacomas & 96-2002 4Runners 5 03-21-2007 05:26 AM
Locked 4cyl diff as strong as 6 cyl diff? deathrunner Offroad Tech 5 10-12-2005 07:19 PM
Contact Us - YotaTech - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
2010 InternetBrands, Inc.
