2003 Tundra Fender Flares
I recently purchased a 2003 Toyota Tundra 2/wd access cab, but it did not come with the stock fender flares (the ones that match the paint color). I am assuming some models come w/ this option because I have seen a few around town and they seem to make a big difference. If anyone has a clue as to how I can purchase fender flares (preferably Toyota made) PLEASE LET ME KNOW!!!! thanks- aP
I have an 04 Tundra and I know that the color-matched fender flares come with the TRD package with the integrated mud guards. I would go to the dealer and find out if you can order them which you should be able to do. I know that if I needed one they would be able to order me up one. And I do need one as I scraped one of mine by backing into the snowmobile trailer! Try the dealer.
Just so you know;on the 03 (and presumably 00 - 05's) the stock flare is mounted through some rather large holes through the fender. I only know from seeing mine apart after a deer caved the drivers side. If you don't want to be drilling large holes you may want to check out the aftermarket (bushwhacker?)
Here's a link to a place that sells the TRD flares. Its says no drilling required.
http://www.trdsource.com/partsbodyrs...3&parts_id=203
I'm not sure if this is the standard TRD flare or if it's the TRD/IS flare.
live4soccer7
05-11-2016 06:52 PM
FS[MidAtl]: 2000 Tundra (Parting out) Pennsylvania
ToyotaMD
11-09-2015 11:53 AM
LCE_Performance
10-01-2015 01:03 PM
4runnerFireman
09-29-2015 06:24 AM
