Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
jeep/fj40
wanted to know if anyone has seen a jeep 4.0 in a fj40 before im wanting to use the motor/trans/case in mine since the fj came with a straight six i think it would look good
| Sponsored Links |
#2 (permalink) |
i'd stick to the toyota engines, proven to be much more reliable than the jeep ones, and i'm sure there are toyota engines which could crank just as well as that straight six, and last a lot longer, just my two cents from what i have read around here before...
plus, i think some people on here might be a little upset to see the two mated together ![]() |
#3 (permalink) | |
Quote:
SBC is a common swap.
__________________
Ben Silva 96 Lexus LX450, 125k, front/rear OEM diff locks, CDL switch, Pin 7 mod, power points, wired 850w inverter, jdm "oh crap" bar, OME heavy (850/863) lift, 285/75/16 Cooper STT, spare tire lift mod 98 Lexus LX470, 135k, Britax car seat ;) TLCA member #14300 Camas, WA USA |
#4 (permalink) |
not worried about adapters going to use the whole drive train minus the axles those motors run pretty well and are fuel injected my friend has a cherokee with the 4.0 with 4.5"lift 32s and stock gears and will smoke the tires down the road cant say that with my 3.slow in my 4runner which i thought about putting into the cruiser.
#5 (permalink) |
My jeep 4.0 in my cherokee had 191000 miles on it. Original engine and trans, didnt burn oil nor leak any. Only thing I ever did was oil changes, plugs, wires, 1 radiator and a water pump. Not to bad but my gas mileage was about 16 on the highway.
#6 (permalink) |
you dont want a jeep motor.... I have a the 1f inline 6 in my fj40 and I can spin my 38's. toyota is the way man just stay with your stock motor
__________________
1997 4runner 2.5in lift 285 bfg mt's,lc wheels. detroit limited slip,been rolled 3 times,fixed and rolled again. (sold) 1976 fj40 Dana60 front 14 bolt rear; lockers front and rear, 38.5 sx's. 99 WB, flat belly, d300 twin sticked. 1996 tacoma extended cab. DD |
#7 (permalink) |
It's a bit late but here goes.
What are you smokin? I understand that saving money in the heat of the moment is important but when one exhibits mallis...well do I need to go on? If you ever plan to sell the FJ40 and you install teh jeep engine, get ready to leave several thousand dollars on the table. No cruiser guy would by it with out an imediate plan to gut the engine compartment. Jus my $.02 from apssionate vintage cruiser owner. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| looking for FJ40 | Big Dog | Items Wanted | 2 | 12-19-2006 10:27 AM |
| Icon Fj40 | Phalanx | 95.5-2004 Tacomas & 96-2002 4Runners | 18 | 11-08-2005 07:56 PM |
| '73 Fj40? | r854rnr | Early Land Cruisers | 1 | 05-08-2004 03:26 PM |
| Fj40 | Sac State | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 07-15-2003 09:20 AM |
| Jeep sues a Jeep enthusiast | Corey | Off Topic Talk | 1 | 12-22-2002 02:06 PM |
