'94 Landcruiser....water sloshing somewhere? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Early Land Cruisers
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-04-2008, 10:15 AM   #1 (permalink)
My wife says she hears a large amount of water sloshing back and forth somwhere when she accelerates or stops. She thinks it's under the floor? She said she lifted the floor mat on the drivers side and it has "green things" growing under it (mold?). I haven't had a chance to look or listen to it yet. Any ideas before I roll over and take it to the Toyota "stealer"?
Thanks!
SOCKO911@comcast.net
EXFFPM is offline
Old 01-05-2008, 03:37 PM   #2 (permalink)
maybe the heater core is leaking? then when it heats up it will flow the water thru it and make a sloshing sound. is the coolant low?
loki2043 is offline
Old 01-07-2008, 11:06 AM   #3 (permalink)
Check the rocker panel drains. The sunroof drains into the rocker panels and the drains get gummed up. You can pull a couple of plastic plugs to get the water out a little better.
__________________
94 FZJ80 fully locked, OME lift, 285s; 95 T100 beater edition; 1995 LS 400.
No problem, I'll tow the pig with a Uhaul Trailer...
"A vehicle's capabilities are inseparably linked to the mental instability of the driver"
Klierslc is offline
Old 01-14-2008, 11:40 PM   #4 (permalink)
Klierslc.....
I did just that....pulled the rocker panel rubber plugs and accelerated and braked and water came out. It didn't flow out all at once, but seems to be decreasing. Where are the "rocker panel drains"? Might they be located between the running board and the rocker panel? I noticed what appeared to be water dripping from the bolt areas attaching the running board to the rocker panel? Thanks for the info so far! Much appreciated!
EXFFPM is offline
Old 01-15-2008, 04:01 PM   #5 (permalink)
I don't remember exactly where they are, and we have a bit of snow on the ground or I would go look, but IIRC, they are slits roughly 1.5 inches long, and not very wide.....
Look here for more info
http://forum.ih8mud.com/80-series-te...rains-faq.html
__________________
Klierslc is offline
Tags
1997, 75, cruiser, drain, draining, fj80, floor, land, landcruiser, leak, loki2043, pan, panel, rocker, series, sunroof, toyota, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
leak from water pump gasket ,water pump dcmbsc 86-95 Trucks & 4Runners 10 08-06-2007 08:46 AM
splashing/sloshing sound when cold DAS_GTI 86-95 Trucks & 4Runners 6 06-17-2007 02:06 PM
landcruiser? mYnAmEiSmUd General Vehicle Related Topics (Non Year Related) 5 11-27-2006 09:43 AM
why not a landcruiser littlerunner General Vehicle Related Topics (Non Year Related) 15 07-13-2006 01:36 PM
My 96 Landcruiser 95FourRunner 95.5-2004 Tacomas & 96-2002 4Runners 13 04-16-2003 04:58 PM
2009 InternetBrands, Inc.
