84 FJ60 EGR cooler tube replacement - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Early Land Cruisers
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-22-2009, 05:27 PM   #1 (permalink)
Hey all.
I'm replacing the egr tube that runs from the exhaust manifold to the cooler and have a couple questions I'm hoping someone has the answers to.
1. I've been reading up on the gasket blowing out between the tube flange and the exhaust manifold. There was no gasket left when I removed the old tube, which was broken at the flange. I've got a ss tube from sor to install, but have read that the sor gasket should not be used, so I plan on ordering an oem gasket and some new locknuts as well. Does anyone know of a good sealant or any other tricks to keep the gasket from blowing out too soon?
2. In order to get the room to be able to fit the new pipe, I am considering unbolting the cooler from the block. I don't have a diagram handy so I'm wondering if there are any gaskets between the cooler and the block. Is this the route most folks follow to be able to fit the pipe to the manifold?
Thanks
SchooBaka is offline
Tags
2004, 22re, 4runner, cooler, cost, costs, egr, exhaust, fj60, gasket, manifold, pipe, replacement, system, toyota, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
EGR Replacement Questions, 84 22RE 3cRider 84-85 Trucks & 4Runners 2 01-07-2009 07:26 PM
Egr With Tube. CHIBA The Classifieds GraveYard 3 11-22-2007 09:03 PM
Broken Egr Valve Tube - Need elmo908 86-95 Trucks & 4Runners 2 04-21-2006 02:22 AM
94 3.0 EGR Replacement colsoncj 95.5-2004 Tacomas & 96-2002 4Runners 6 06-18-2004 02:45 PM
radiator replacement: auto-cooler outlets? ohio 95.5-2004 Tacomas & 96-2002 4Runners 13 12-30-2003 10:16 PM
2009 InternetBrands, Inc.
