63 fj 40 ball-joint front axeles - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Early Land Cruisers
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-02-2009, 08:46 PM   #1 (permalink)
Question 63 fj 40 ball-joint front axeles
no ever talks about the ball joint just the birfields any info would help
wwfj40 is offline
Old 11-02-2009, 09:01 PM   #2 (permalink)
SC4Runner's Avatar
The ball and claw style axles? Well they are known to be the weak point in the early FJ's. Also, they aren't very desired because you are unable to do a disc brake conversion easily.
What exactly are you looking for? Diagrams? The axle housing is also different/smaller than the post 67(?).
__________________
1996 4x4 3.4L 4Runner on 35's - 6" of lift, MTR's, E-locked, ARB Tacoma Bumper, Sliders and a cut off tail pipe.
1966 FJ40 - SOA with stock springs, stock 1F motor, and a smelly tailpipe.
SC4Runner is offline
Old 11-03-2009, 09:43 PM   #3 (permalink)
Question 63 fj40
well iam trying to figure best way to put disc brakes on it i have a 82 truck front end i want to swap the disc brakes off
wwfj40 is offline
Old 11-04-2009, 12:18 AM   #4 (permalink)
Well, i would suggest getting a set of later style FJ40 inner axles, grinding inside the ball (for clearance on the birf) and slapping that junk on it! Use the birfs from the mini, one of the axle shafts might be the correct length but i can't remember off the top of my head, ih8mud tech has all the info you would need there. The mini rotors aren't the best but a bunch better than drums!
Edit: i am assuming you realise that you need the entire knuckle setup and will need different steering arms...
__________________
77 FJ40 36 TSLs, 45 springs in rear, 8274, ARB rear, TBI 2F
97 4 Runner Ltd
TLCA# 9203
FlyingLow is offline
Old 11-04-2009, 10:11 PM   #5 (permalink)
Cool
so it sounds like i should scrap the idea because after all i still have the birfield
wwfj40 is offline
Old 11-05-2009, 05:40 AM   #6 (permalink)
Quote:
Hell no, go ahead with it. you need to use the minitruck birfs, knuckles and breaks. You will need one or 2 inner axles though.
Birfs are great!
__________________
97 4 Runner Ltd
TLCA# 9203
Tags
63, ball, brakes, fj40, joint
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
