Another "Getting into RC..." thread
Yep. I seen enough so i asked Santa for one for Christmas. Now i just gotta figure out what i want.... well, i know what i want, i just cant figure out how to put it to a brand name.
Ive read all through the threads but theres some things i cant figure out the difference/need for some things. For instance, 1.9 vs. 2.2 - From what i gather its wheel size. But what does this mean to me?
Basically what i want is something that looks like a miniature real truck but really capable off road. From what i understand so far, an Axial Honcho would fit my desires the most and i could just change the body to something i like.
But if i get a Honcho and beef it up to how i want it, will i still be able to go on rides with local groups? Or will i get shunned because i dont meet ### competition code?
I had a bunch of buggys and monster trucks as a kid but it seems like things have really changed since then.
Any help clearing this up would be greatly appreciated.
about the only time you have to really look at your upgrades/changes and see what you should or should not do is if you plan on entering any sort of event or competition. then you have to comply with tire size, tire weight, complete rig weight, and a few other regulations
the way things are going in the RC world, at least from what I see, is that the old top-notch Nitro cars and trucks that were all the rave are now taking a back seat since brushless electric power has really advanced. the aftermarket has really stepped in, and there's hop-ups for pretty much ANY RC car/truck out there, even for many that aren't considered a "hobby-grade" RC. it's definitely a fun hobby to get into. it can get expensive, that's for sure and although you can't sit on your 1/10th scale Toyota and ride it through the trails, I still feel it's a very rewarding hobby
What do you think of this deal? Its listed on a local RC forum. I emailed the guy and he said it includes everything i would need to get into it including a charger.
Ax10 comp truck w/locker, steal shafts, full bearing set, mamba max speed control, lipo batteries, Spectrum 3 channel radio and intellipeak Ice Charger and to many upgrades to list comes with many extras $225
sounds like a pretty good deal, but the AX10 is a comp rig, not a scaler
BUT, the AX10 shares a LOT of parts with the SCX10. it you wanted to convert it to a scaler, I believe all you would need is an SCX10 chassis frame rails and cross bars
if you know you want a scaler then i would recommend you start with a scaler instead of converting a comp rig into one - it's just easier this way. you can easily find a used scaler in the $200-300 range and the new ones are around $300+ - sometimes you can find a hell of a deal on a used scaler with lots of aftermarket goodies in the $400-500 range. some people DO convert their rigs or just slap a scaler body on their comp rigs, but it's either a lot of work/$ or it isn't a true "scaler". I do know that an SCX10 chassis by itself is in the $50-60 range if you want to convert. I can't say exactly what's involved since every body will require a different setup - but it's definitely more involved than just swapping the chassis.
the ax10 and the scx10 share a lot of the same drivetrain components since they're both crawlers - this would be everything connecting the motor and axles. Where they will differ is with the suspension-related items since one is they have completely different chassis and suspension setups - but again, since everything is customizable with an RC this doesn't really matter if it's what YOU want. the term "scaler" is directly related to the proportions of everything and basically imitating reality on a smaller scale - so that's why a lot of scalers will have ladder frames, chassis-mounted steering boxes/servos, etc. here's a really good list of scaler guidelines.
as for the tires "class size" - like bleeder said, the 1.9" vs 2.2" refers to the wheel/bead diameter and has nothing to do with the outer diameter of the tires except that each size wheel is a "class size". Within each of those class sizes, there are a number of different tires available, each of which will have differing outside diameters, tread patterns, and rubber compounds depending on application or scale representation. Sometimes people will simply refer to their rig as a 1.9 or 2.2 rig but it does not mean that their rig is actually a "scaler".
you will find that 1/10 scale is the universal "scale" size for a lot of the stuff out there and 1.9 tires are the more popular size that fits in that body range - competitions usually seem to put a cap on 1.9 size tires being the largest you can run in scale comp. Doesn't mean you can't make a huge scaler out of a power wheels or smaller one with a model car. if it were me looking for a rig, i would go with an Axial SCX10 - seems to be the most popular for what you get in the box and aftermarket support. it's definitely not the only option though - here's a RTR, RC4WD scaler for $300 and it's much more scale than the SCX10.
good luck - i'm sure you'll be happy with whatever rig you choose
Theres a bone stock Honcho on my local craigslist for $250. It just has the truck, radio and battery. So would it be better to get the AX10 with a ton of goodies on it and lipo battery and convert it to an SCX, or buy the stock SCX and build it up?
Bottom line, either way im gonna screw with it.
joeynational
09-05-2015 01:54 PM
86 87 4Runners
09-05-2015 06:02 AM
86 87 4Runners
09-02-2015 03:54 AM
