Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
Toyotafiberglass - Supertoy
Old 10-11-2011, 04:02 PM
  #61
slacker's Avatar
so a little bit more cutting
also .. interior is now completely gutted ..
anyone need some good floor boards ?
Old 10-12-2011, 05:14 PM
  #62
slacker's Avatar
my first bend with my new bender
2" OD Sced 40
It's actually going to be my bend tool .. so I'm going to try out my powder coating as well with powdercoating it and saving it
I have to still "draw" up my tube work in my solidworks software so stay tuned .. STOKED !!
Old 10-22-2011, 04:19 PM
  #63
slacker's Avatar
added some rear suspension today ..
not done yet , still some tube to add , but the rear is off the jack stands
Old 10-22-2011, 07:15 PM
  #64
TinMan's Avatar
As always looking. Wish I was closer to come over and learn a thing or two.
Old 10-25-2011, 05:33 PM
  #65
slacker's Avatar
mght even put you to work
Old 10-25-2011, 07:38 PM
  #66
jsn_stockard's Avatar
Slacker I bow to you're awsomeness!! I have been kicking the idea around of doing something like this to a 91 that I can pick up pretty cheap. Love the custom frame, and I will be stalking this thread like a psyco ex girlfriend on meth!!!!
Old 10-26-2011, 03:47 PM
  #67
slacker's Avatar
thanks ..
found some time today , so I finally cut the floor out for the body drop
Old 10-28-2011, 04:18 PM
  #68
slacker's Avatar
prepping the inner rockers for the new body mounts .. I of course found rust .. so now I have to fix that first .. I was really surprised , this cab was in awesome shape no rust at all , or so I thought .. just goes to show you , even if you think you have no rust .. you probabally do !!
undercoating wire wheeled off , and looking great
and cut out rust !!
Old 10-29-2011, 03:55 PM
  #69
slacker's Avatar
1 side done .. and ready
Old 10-31-2011, 04:07 PM
  #70
slacker's Avatar
also got the drivers side cleand and prepped this weekend
and .. drivers side has rust as well
I think to be safe , i'm going to cut it all out .. front and back rocker area , and strengthin both sides before I build the body mounts
and just for some giggles ..
heres the pile of removed edging and ground steel ..
Old 10-31-2011, 06:48 PM
  #71
TinMan's Avatar
Yep cut that crap out. You know the deal. If you skip it, it will haunt you later.
Old 11-01-2011, 04:33 PM
  #72
slacker's Avatar
absolutly ..
Old 11-02-2011, 10:44 AM
  #73
yotasavg's Avatar
wow i'm not even sure that i know what's happening here anymore.... What's going on with the rear drive setup? looks awesome!
Old 11-02-2011, 10:48 AM
  #74
yotasavg's Avatar
went back and reread the beginning, now it all makes sense, idk how i missed that... this is even better than i thought it was going to be lol! NOW I'M REALLY IMPRESSED!
Old 11-02-2011, 04:51 PM
  #75
slacker's Avatar
thanks .. stay tuned ..
this build is going to be NUTZ
Old 11-11-2011, 05:45 PM
  #76
slacker's Avatar
so over the last week , I have been building my repair panels and today I was able to get them burnt in , rears as well
now with the rockers repaired , I was able to get the cab height finalized @ 9" from the rockers to the Ground . + I also started on the cab mounts
Because there are only going to be 4 mounts instead of 6 , I wanted to make sure there were going to be strong .
cut out some 3/16" plate and surrounded it with some tube
Tacked into place I will add some more supports later , when I turn the frame over .
1 more front frame mount tomorrow , then I can get on the front cab mount
Old 11-11-2011, 08:38 PM
  #77
TinMan's Avatar
Looking good. What are using for a tube bender?
Old 11-12-2011, 05:02 PM
  #78
slacker's Avatar
I bought a magnum bender , it's a "manual" bender , just like the JD2 bender . KMS tools had a big sale and I got a super deal , includuding 3 dies .. I just couldnt pass it up
Old 11-12-2011, 05:47 PM
  #79
slacker's Avatar
and cab side mount
Bent up some 1/2" solid stock with the 3/16" plate . as well as a "fish plate" for the cab side , 1/2" stock actually goes threw the fish plate for a stronger "plug" weld , and a toyota stock body mount bushing , I now have the front mounted
and now the front of the cab is mounted
still have some supports and final welding to do when I can turn over the frame , but for now it's good to go
also .. the cab now has it final "stance"
acetone can for referance ....
Old 11-13-2011, 05:14 PM
  #80
slacker's Avatar
ok .. so I had a "peek" at the beginnings of this thread , and it didnt really start from day 1
so I'm going to refresh and let you all know the start of the build .
The build started with the stock truck which I had rebuilt the 22RE engine
although a great engine , it just wasnt what I wanted anymore ..
so , I bought a Supra
and "gutted " it
Quick Reply: Toyotafiberglass - Supertoy
