Looking For A Mechanic/Fabricator/Shop Put your location in your thread title when making an inquiry
Erratic idle. Suggestions?
Old 01-01-2016, 02:30 PM
tj884Rdlx's Avatar
Erratic idle. Suggestions? Atlanta, GA area
Edit: sorry this is not the section i meant to post in. But I'm in Atlanta, GA metro area
Idle has always been erratic in the past. Sometimes it would stick higher, around 1200. Tapping the gas would drop it back in line to about 900.
But only occasionally. Lately it's doing it a lot. But now idle is coming down to around 550. And sticking as high as 1400. My old carb'd VW would do this. But this is efi.
If i tap the gas enough it will straighten out and hold at 800 nicely. But then drive away and come to another stop, and go through it all again.
I've had multiple shops try to resolve this. They all failed as it still does it. It's been years.
I wish i could get this handled once and for all. Any good ideas? I've got to do something but i don't know what. Tired of putting this off
88 22rec
Last edited by tj884Rdlx; 01-01-2016 at 02:34 PM. Reason: Added location to confirm to section rule
Old 01-01-2016, 02:38 PM
tj884Rdlx's Avatar
When i look at the throttle flap during the fault condition, i can see it's sticking open. I just press on the bar where the return spring attaches and it closes easily enough, and idles right. I've replaced this spring, and the little one way air valve that dangles next to it. Neither helped. I've pulled the boot and sprayed cleaner all around the flap. No help.
TheGrits
02-23-2024 09:54 AM
arlindsay1992
01-23-2016 05:19 PM
nekchris
12-31-2015 08:16 PM
davehaynes1
12-29-2015 07:25 PM
maroonyota
12-27-2015 01:20 AM
Quick Reply: Erratic idle. Suggestions?
