| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Yet ANOTHER key problem : Wont work in back gate, weird problem
#2 (permalink) |
Guest
I would'nt think that the latch would be broken, rather I'd think that the rear door takes a different key.
It could be that when they were rekeying it they "keyed" everything except the rear door, or..., the wiring harness connector is disconnected and you need to pop off the rear interior trim panel and take a look.
#3 (permalink) |
no the key wont even turn in the cylinder.
the window works and the door lock works fine as lone as it operated by the key remote, or the switch on the door. |
#4 (permalink) |
i was planning after work on monday to get a normal flat key cut to keep as a spare in my wallet in case of accidental lock out, so if i get it done ill post up and let you know if it works in the tailgate.
#5 (permalink) |
Guest
Then it could indeed be that they overlooked the rear door lock when they were rekeying it after the repo.
I'd say contact the dealer you got it from about their putting you in touch with the locksmith that they used or have it done yourself.
#6 (permalink) |
I had a couple spare keys made and many times those keys wont work in the back gate. The back gate cylinder is figity some times, doesnt like to work properly. it might just be that a copied key might be a little bit off so it wont work properly.
__________________
95 4Runner SR5 3.0l. V6 2 wheel drive baby! 31" Bridgeston Dueler A/T Revos. Downey 1.5 Coils. Doetsch MV-12 Shocks. Brembo Rotors. Performance Friction Pads. Pioneer head unit with 1 12" Pioneer woofer. XM Radio. RB Headlight Harness w/ Sylvania SilverStars New to the family: 85 4Runner 22RE, 4x4, 5 spd, SFA. 31" BFG All Terrain T/A KOs, genuine Walmart seat covers, "Dual" stereo, XM Radio, RB Headlight Harness w/ Sylvania SilverStars. Onboard air. Has been seafoamed to hell |
#7 (permalink) |
Maybe its a valet key?
__________________
2005 4Runner Sport 4x4 v8 OME Lift, BFG At's |
#8 (permalink) |
trd2001, cant be becuase he said it opens the glove box
__________________
#9 (permalink) |
Check the VIN on the tailgate and make sure it matches the VIN on the dash. I swapped tailgates and had to swap the cylinder to be able to use the keys I had so it would function with the new tailgate.
__________________
Stephen SOLD! 99 4Runner Limited, Jade Mica. 08 4Runner Urban Runner Edition 4wd. Blizzard Pearl White...Let the mods begin! |
#10 (permalink) |
I have a similar issue in my 90, I have a "Toyota" key that opens drivers side and does ignition and I have a copied key that opens shotgun. My tailgate window didn't work until a couple weeks ago when I replaced the regulator and motor, I tried both keys and neither of them turn the cylinder. I left it at that for now because I am happy enough to have a gate window that works at all. I just keep my eyes open for a deal on a lock cylinder with a working key!
#11 (permalink) |
What was the final resolution on this?
I have the same problem on the 98 I just purchased. I had a valet key so I got two new keys cut from Toyota based on my VIN number. I can lock the glove box now, but no luck with the rear latch. Both new keys will go in, but the lock won't turn at all. Hatch opens fine when the doors are unlocked and the window goes down fine from inside. Thanks, Phil
__________________
98 4Runner SR5 4WD, Desert Dune Revos, Custom mounted Hella 550s, Yakima Rack 99 Corolla, 38mpg. |
#12 (permalink) |
Here's an update on how I solved this:
Tonight I sprayed some silicon spray where the key goes and wiggled it several times (firmly, but not hard enough to break the key) and after a few times it started working. I"m guessing it was corroded or siezed for whatever reason. I read somewhere on Yotatech about corroded locks so I figured I'd give it a try. Gotta love those easy fixes
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| weird cooling problem | elkdog | 86-95 Trucks & 4Runners | 6 | 06-13-2009 10:09 PM |
| Weird idoling problem(seem weird to me) | yotakid825 | 86-95 Trucks & 4Runners | 10 | 06-04-2007 12:19 PM |
| key or ignittion problem..cant tell which.. but cant turn key | sabre | Maintenance & Repair Archives | 3 | 06-27-2005 12:28 PM |
| runner key problem | calrockx | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 10-10-2003 02:12 PM |
| Weird problem | nags | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 01-10-2003 06:02 AM |
