Where is the fuel filter on my 3rd gen?
Old 10-01-2005, 09:30 AM
fo_runner's Avatar
I have a 2000 4runner with the 3.4, and I can't seem to find the the fuel filter. I already checked the tech section, but my truck has a huge skidplate covering the driver side undy-body
Could the fuel filter be hiding under this skidplate?
Old 10-01-2005, 09:38 AM
X-AWDriver's Avatar
Yes it is.
Old 10-01-2005, 11:02 AM
Elton's Avatar
here this will help http://www.4runners.org/articles/fuelfilter/
Old 10-01-2005, 02:18 PM
BajaRunner's Avatar
Its right under your drivers side rear seat door... Just get under and look up. Its attached to the bottom of the body.
I wouldnt recommend changing it though.... Its a pain in the ass because you have to deal with fuel and its torqued on there really good.
I didnt gain any performace either. Just an hour out of my time
Old 10-01-2005, 02:25 PM
calrockx's Avatar
yep, right under where you sit in the driver seat.
i changed mine. it wasn't hard at all. but yeah, no performance gain.
Old 10-01-2005, 08:08 PM
fo_runner's Avatar
Thanks guys, I decided not to change it since the car is only 5 years old, and still running decent. But, I did pour in some Redline fuel system cleaner to get rid of some the crap in the fuel system.
Old 10-01-2005, 08:10 PM
Localmotion's Avatar
hmm...ive got 200k on mine. Do you think i should replace it?
Old 10-01-2005, 08:22 PM
Lone4runner's Avatar
I was told that if i changed my fuel filter at this stage(100k) I run the risk that the filter may not go back on. If that becomes the case the fuel line may need replacement. So at this moment i am going with the advice that ill let the filter and lines rust to the point they need to be replaced
Old 10-01-2005, 08:24 PM
good info..ill just leave it be then!
Old 10-01-2005, 08:27 PM
fo_runner's Avatar
Toyota says these fuel filters are lifetime filters, so they don't have to be replaced. I think this is b.s. Go ahead and change it if u want, no one's stopping you.
Old 10-01-2005, 08:34 PM
yeah i kinda heard the same thing. I also think its b.s. cause I know eventually it will. its just that it would really suck to have to change your lines too. I know others have changed it w/o problems but as with all things its a risk you take. On top of that I dont think it would do too much to help the fuel flow taht much better for the risk.
Old 10-01-2005, 08:47 PM
fo_runner's Avatar
Fuel lines are not so easy to replace, and once you know they're rusted, you'll know theres lots of crap in your engine too. Thats my $0.02 cents.
smthwsn357
12-04-2023 02:08 AM
Eggslinger
06-08-2019 03:32 PM
Alex Bessinger
08-31-2015 09:17 AM
pyramid
07-30-2015 10:05 AM
Fundy Rider
07-16-2015 01:35 AM
Quick Reply: Where is the fuel filter on my 3rd gen?
