What octane gas do you guys run?
Old 08-20-2005, 09:22 AM
  #41
ironroad9c1's Avatar
Originally Posted by LittleRedToyota
unless your engine is pinging, you should run whatever octane the manufacturer suggests (should say in your owner's manual).
running higher octane gasoline will reduce pining, but it can actually increase carbon build up.
higher octane does not mean the gas is "better"...it just means it is harder to burn (which is why it stops pinging).
carbon build-up is caused by incomplete combustion.
fuel harder to burn = more likelihood of incomplete combustion = carbon build-up.
engines are designed to run gasoline with a specific octane rating. if you run an octane level higher than what the engine is designed for, you can get incomplete combustion (because the gasoline is harder the burn than the engine was designed for, so the engine does not completely burn it).
the result, over the long-term, is carbon build-up.
now, once you already have carbon build-up, you may need to switch to (or continue running) higher octane fuel. the reason is that the carbon build up effectively reduces the volume of the combustion chamber, thereby raising the compression ratio (higher compression requires higher octane). also, the carbon deposits retain heat, thereby raising the temperature of the combustion chamber.
however, if you do not have pinging problems and your engine is stock, you should run the recommended octane level, not higher or lower.
thank you ,you kept me from having to type it ..lol if you get pinging then something is wrong
Old 08-20-2005, 10:06 AM
  #42
Chuki's Avatar
I have to run either 91 or 92. Sometimes I can get away with 89 but it usually pings. Used to run 87 octane but it slightly pings underload and gas mileage was crappy, around 16mpg or so. 89, it's a guess of 50/50 of whether it will ping or not. So I run 92, no pinging, engine runs smoother, feels a lil more peppy, and gas mileage is around 20mpg.
My guess is either I have bad knock sensor, or carbon buildup.
Old 08-20-2005, 09:13 PM
  #43
bike4miles's Avatar
89 is what I run
Old 08-21-2005, 08:27 AM
  #44
LittleRedToyota's Avatar
Originally Posted by Chuki
IMy guess is either I have bad knock sensor, or carbon buildup.
my guess is carbon build up--try seafoam (sucked through one of the little vacuum hoses attached to the throttle body).
there have been a number of threads about seafoam on this forum...do a search for it and you'll find all kinds of info.
Old 08-21-2005, 08:31 AM
  #45
Rivalred's Avatar
Run 87 octane..
Old 08-21-2005, 10:54 AM
  #46
Chuki's Avatar
I'm pretty sure thats what it is, but I've got almost 170k miles on it, and I think cleaning that off at this point in time probably wouldn't be a good thing...
Although I'm tempted to slap a couple cans in the gas tank.
Old 08-21-2005, 11:45 AM
  #47
VolcomTacoma's Avatar
I use 87 Chevron religiously.
Old 08-21-2005, 01:14 PM
  #48
chillydog's Avatar
93 octane, Toyota highly recommends it for 4th gen V8.
slider417
06-22-2015 10:18 AM
bobbybouche
06-18-2015 10:22 AM
UKMyers
11
06-24-2002 05:41 AM
Quick Reply: What octane gas do you guys run?
