What to do with the front flooring of a 4Runner/why is it leaking?
Old 11-28-2005, 07:16 AM
cgardner's Avatar
Plugged Sunroof Drain
I had the same problem. If you have a sunroof, use compressed air to blow out the little drain holes in the window channel. It actually runs through a tube by the front cowl and when it clogs, makes the passenger floorboards wet.
Old 11-29-2005, 03:16 PM
rngrchad's Avatar
When someone actually goes to fix this problem, would you PLEASE take a picture of the grommet/wire harness area near the plenum! Or when you find out where it is leaking through, take a pic.
Thanks.
-Chad
Old 12-01-2005, 04:04 PM
94dodgedakota's Avatar
I will make sure I take some pics...The AC line is busted and it is 18 degrees here so I haven't used it!!! I blew out the sunroof holes...I am trying to pull it in my buddies shop this weekend and look at it. It seems to leak around the computer as well...I will keep you posted and thanks once again.
Old 12-01-2005, 04:15 PM
rngrchad's Avatar
No, thank you.
Please remember to post this fix, as I know many other tacoma owners who have similiar problems.
Old 12-14-2005, 06:35 AM
  #25
dannyh's Avatar
Same problem with my 90 4runner. Passenger carpet always seems to be just a little damp. I thought it was my floorboards.
I'll check this as we do the sas
Old 12-14-2005, 10:27 AM
  #26
FORANA's Avatar
I had a 87 that had wet carpets. my problem was that the tire wells have holes due to rust. Pissed me off cause I didnt find it for like a year, then I went through a huge puddle, got real wet, and the light bulb above my head went on. Silicones and taped the crap out of it and I was dry.
Old 01-17-2006, 03:35 PM
  #27
waskillywabbit's Avatar
My 87 4Runner leaks like a waterfall on the passenger side when parked all day like it was today...and I'm pretty sure it isn't the windshield. I'll do some investigative stuff soon and post what I find. Some good advice here on this thread...gotta be a grommet/sealant somewhere not doing what it is supposed to do.
jasonty
41
12-23-2018 01:00 PM
88sasturbotoy
08-11-2015 01:56 AM
andrewtexas123
07-14-2015 04:29 AM
Avenged
07-09-2015 07:55 AM
Quick Reply: What to do with the front flooring of a 4Runner/why is it leaking?
