weird grinding noise from rear end - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-11-2005, 07:21 AM   #1 (permalink)
dirtypuke's Avatar
hi i am new to this forum, i have read ALOT of the the threads and the tech threads and am very impressed. well down to the question, i have a 98 4runnner 4wd and it is making a grinding noise when i let of the gas pedal?.?. i have read that many other people have had this problem, so what is the problem? i have rulled out the brakes, the ujoints and the rear axle being low on gear lube because i changed the fluid and didnt notice any chunks. i am baffled.
dirtypuke is offline
Old 11-12-2005, 10:19 AM   #2 (permalink)
OicnaiC's Avatar
Send a message via AIM to OicnaiC
It could be the gears are just worn out, but that's uncommon from what I understand. More likely it's one of the bearings in the 3rd going out. Have you had your rear axle under water at all, or did you run with really low fluid for a while?
__________________
'91 4Runner SR5, 3.0 V6, 5spd | Downey HD coil springs | 2" Body Lift | 33x10.5 BFG A/T's on Black Steelies| Hand Throttle | Custom Flowmaster/SuperTrapp exhaust | 1st Gen. Roll Bar | Custom "Pinstriping" | Over 245,000 miles and still kickin
OicnaiC is offline
Old 11-21-2005, 02:45 PM   #3 (permalink)
dirtypuke's Avatar
yeah it was the front pinon bearing. it was pitted. so i took it to the tranny shop and they replace all the bearings and seals for 400 bucks. oh well i hopefull wont have to worry about this for a while.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
99 3.4 weird grinding noise and water on drivers side? justin1889 95.5-2004 Tacomas & 96-2002 4Runners 8 11-22-2006 05:29 AM
HELP: Grinding noise out of front end. davemacneil 86-95 Trucks & 4Runners 11 10-25-2006 12:18 AM
Rear end grinding noise TACOMANATOR Maintenance & Repair Archives 0 11-06-2005 06:39 PM
Weird noise coming from the rear end - HELP!! mattyp12 Maintenance & Repair Archives 5 06-22-2005 12:04 PM
Tacoma 4x4 front end noise(rubbing/grinding) Rob02 95.5-2004 Tacomas & 96-2002 4Runners 0 04-07-2003 01:57 PM
2009 InternetBrands, Inc.
