Valve cover stuck?
Old 02-15-2009, 09:13 AM
Ken
Ken's Avatar
Exclamation Valve cover stuck?
I've got the intake, throttle body, etc. removed, plus the 8 bolts that hold the valve cover itself. However, the cover will not budge with hands-only force (no hammer/chisel ). Any tips on removing the cover without potentially damaging/warping it?
Old 02-15-2009, 11:16 AM
eric-the-red's Avatar
Get a plastic hammer and bang it around the edges. It's probably just stuck on the gasket or silicon. You can also try carefully cutting around the seal with an Exacto knife. Don't try prying it by sticking a screwdriver in the seal, you will probably just bend the flange and make it leak later.
Old 02-21-2009, 12:58 PM
Ken
Ken's Avatar
Cool, finally got it off!
I can only work on it weekends nowadays...
Old 02-21-2009, 08:40 PM
skjos's Avatar
What method did you use to get it off? If I ever need to do this in the future it would be good to know.
Old 02-22-2009, 06:04 PM
Ken
Ken's Avatar
There are a few tabs extruding from the edge of the cover. One of these is next to the power steering pump bracket. I was able to use that as leverage and gently pry off the cover.
calderp
Engine Swaps
08-16-2016 05:15 PM
09-04-2015 09:27 AM
irritech
07-27-2015 05:15 PM
calderp
07-27-2015 09:58 AM
keithporter83
07-18-2015 12:37 PM
Quick Reply: Valve cover stuck?
