vaccum line pics for 98 s/c
not sure my lines are proper...should plug on back of the s/c be plugged if not running a boost gauge..anyone that could supply me with pics of the vaccum lines from would be great...the diagram supplied with S/C is sort of vague, etc.
thanks.
thanks.
Originally Posted by gadget
With the FPR hooked to the boost port it will react to boost pressure and increase the fuel pressure under boost at a perfect 1:1 ratio.
Pretty sure that the boost port goes to the fuel pressure regulator (tight fit between the back of the SC and the firewall as I recall).
09-04-2015 09:27 AM
pyramid
07-30-2015 10:05 AM
