URD SuperGrip Crankshaft Pulley for 3.4L Toyota Trucks
I just wrap an old bike tire (bike stores have plenty to toss) around the pulley and then use a chain wrench.
Works like a charm and won't scratch the part at all.
Not to open a can of worms here, but it should be noted that bottom-end balancing concerns come into consideration with lightened crank pulleys. Obviously this may or may not apply to the 5VZFE, but it should be at least noted or open for discussion. There are both praise and horror stories both all over the net about lightened crank pulleys. To be honest, I am not sure what I think. I can't say because I don't have a lot of bottom-end experience.
All I know is in regard to Honda's and what speed shops, such as Superior Racing, have told me. SRD is a leading manufacturer of lightened crank pulleys and they told me over the phone they would not run one on a daily driver due to increased wear on the bottom-end. That scares me a bit. Also, why does URD say this is for "[race] prepped" engines?
Your thoughts?
Your thoughts?
Your thoughts?
Your thoughts?
#25
Your thoughts?
Your thoughts?
If you have a 5 speed i think the 10 lb crank pully is negligable compaired to the 40lb flywheel hanging off the back end. (Which has a MUCH MUCH larger radius of gyration)
The reason for "good for race motor" is usually the motor is bluprinted and ballanced meaning there should be no worry about addtional mass dampener needed in the form of crank pully or flywheel
#26
Originally Posted by yota5VZFE
Hi Chris, just because you spoke with someone over the phone from that person's opinion, that scares you from installing a lighter crank pulley ?
I found some articles, and all seem to emphasize the use of the harmonic balancer no matter what.
One can argue the pulley question from two sides. First there is a stright forward technical issue of elimination of the harmonic balancer portion of the crank pulley. There is one series Honda engine for which they have stopped selling pulley kits because the crank main bearing are particularly sensitive. Harmonic balancers are a needed component to protect, usually the front bearing of the crank from periodic vibrations that can occur at certain rpm in any engine. Over time vibrations can cause or aggravate wear. Do not bother to argue with someone who denies this fact or tries to tell you some story about how racing engines do not use them or what ever. Rubbish. You want to keep your harmonic balancer in place. Period.
Allegedly some main bearings destroyed by a lightened crank pulley on a Honda motor:
WARNING: Some companies have been marketing replicas of UUC's original pulley design, but advertising them as superior due to "light weight". This clearly shows these replica manufacturers do not have an understanding of the underdrive concept... weight reduction is not a factor in producing power with underdrive pulleys... the gain comes from reducing the accessory speed, not from less rotating mass.
While some pulley advertisers do advertise "lightest weight", we feel that to be somewhat deceptive... in our extensive testing, we have proven that the actual weight of the pulleys is not a factor in increasing power gains whatsoever. Each pulley itself weighs just a few ounces... shaving off a small amount of additional aluminum will not make one single bit of measurable power. Weight savings in a BMW that are important are in the much larger rotating components such as a lightened flywheel or lighter road wheels.
Those are a few of the negatives I could find. I don't know what to think guys.
#27
i think we need an answer from someone who has run one for a conciderable time period, i would like to hear it wont hurt my motor because im interested in getting one.
#28
Do some searches on google and you will find a day's worth of reading on other vehicles, FWIW.
#30
Anyone run a lightend flywheel? I can tell you from first hand experience that the lightend flywheel they sell for BMW's makes a WORLD of diffrance. VERY noticable....
but thats a flywheel on a BMW not a crankpully....
as for these
it looks like they ran it out of oil. discoloration is a shure sign of getting hot. vs an uneven wear that you might expect if the crank was vibrating...
as for these
#31
Originally Posted by ebelen1
Are you talking about me? That's OK because I have been a "Doubting Thomas."
#32
There were a couple of guys on the web a couple of years ago that were running lightened flywheels on their 4 runners (2nd gen). They said it made a huge difference and helped counteract the big tires. I haven't been able to find it again. It was a personal website and had a picture of a red 2nd gen with a snorkle.
#33
I run a lighted flywheel in my civic and yes it makes a huge difference. But a lightened crank pulley or pulley without a balancer is another story. If they were a safe option for daily drivers dont you think TRD would offer one? Also Dinan (the trd of bmw) does not offer a lightened crank pulley either.
Only reason why I mention them is cause they are the only other company that comes to mind that will warranty their aftermarket parts. If anyone knows another please check and see if they offer a light crank pulley.
#34
Does anyone know if there is a company out there that makes a lightened flywheel for 3.4L engine that is available for us to purchase ? so far, I know URD recently developed a lightened crank pulley for sale at $279. I don't know if URD will develop a lightened flywheel soon for the 3.4L, I would imagine it would be a nice mod.
#36
Originally Posted by dexter
im getting one with my urd kit and mister. i run a lighter fly wheel on my truck and love it
#37
http://www.google.com/search?hl=en&q...ywheel+4runner
And for $450...
http://www.mach1car.com/Product.aspx...&p=UR061211000
And some old babble (from 1998) talking about running light flywheels off-road...
http://barneymc.com/toy_root/techtal...ne/fly_whl.htm
#38
Mine is 2002 4runner and it has 3.4L engine, I guess this flywheel should fit right since they are all 3.4L from year 1996 to 2002 ?
