URD O2 simulator install help
Old 04-13-2007, 05:43 AM
aquasport17's Avatar
I got my O2 simulator from URD, but it came with NO instructions. I'm wondering if anyone can give me some tips on what wire gets connected where, while I am waiting for them to get back to me? I have a 2000 4Runner.
Old 04-13-2007, 05:52 AM
NaeSLaS's Avatar
Looks like it hooks right up to where the oxygen sensor used to plug in, as well as a steady ground.
Now what goes where, thats a question beyond me. I assume you replaced the exhaust and left the wire connector just hanging? That should house all the wires you will need.
Old 04-13-2007, 05:53 AM
kevin444's Avatar
pm me your email, ill email you the wiring diagram. since u got the 00 4runner like me. lemme know how your install goes, i still get a CEL roughly 80miles after usage/ecu reset.
kevin444's Avatar
that is wrong is hooks up where the pins out go into the ecu. Thats what i initially thought at first but i was wrong.
Old 04-13-2007, 05:54 AM
Actually, it goes under the dash, and I need to find the O2 sensor wire, cut it, and splice in the box, and ground it. I just don't know what wire is what.
Old 04-13-2007, 06:03 AM
Kevin, do you have the unit installed? If your still getting the code, that is dissapointing. I'll PM you for the diagram. J
Old 04-13-2007, 06:05 AM
NaeSLaS's Avatar
hmm...their site is kinda misleading then.
I still think every product out there should have a PDF of the install instruction available on their website.
Old 04-13-2007, 06:08 AM
MTL_4runner's Avatar
Fink had the same thing happen when he installed his O2 sim (kept getting a CEL), but found out he had it hooked up wrong when he emailed Gadget. Email Brian over at URD and ask him for the wiring instructions for your truck, he's a good guy and he'll get you what you need. More than likely you don't have it hooked up right either if your getting a CEL for P0420 or a rear O2 sensor code.
Old 04-13-2007, 06:51 AM
TRDatVT's Avatar
I have mine installed with NO cats on a cali emissions truck and have had 0 CEL since i put it on around 15,000 miles ago. I will look for the install wiring diagram (my 99 had a different wire color than what was said but i have a full truck diagnostic wiring diagram that labels them all and re-routed it to the correct wire) Do not just hook it up, make sure you check the wires and colors as sometimes they can be slightly different.
Old 04-13-2007, 07:15 AM
kevin444's Avatar
yeah i got the 136 error like rear 02 malfunction
kevin444's Avatar
are you running the simulator?
Old 04-13-2007, 08:04 AM
Ok, it's insatalled, and the CEL was reset when the battery was disconnected. Now we wait and see what happens.
Old 04-13-2007, 08:12 AM
Yep, that was exactly the same issue as what Fink had!
https://www.yotatech.com/forums/f2/california-dual-cats-82360/ (read the end of the thread, post #21 and on)
Old 04-13-2007, 04:22 PM
TRDatVT's Avatar
Yea the simulator is installed... Without it i get a CEL in a few miles for a cat inefficiency error.
Old 04-15-2007, 07:38 AM
Well, it's gone from bad to worse. After the install I drove it no more than 40 miles and it threw a P0125 and a P1135.
So, either I have it installed incorrectly, or something else is wrong. I installed it according to the instructions Kevin sent me. I dunno what's going on.
According to the instructions, the black wire is spliced into the Plug B Pin 18 wire. From what I have read, I thought the black wire was for ground. I connected it per the instructions, however, to the blue/black.
Any ideas? I'm doublechecking my work now...
Old 04-15-2007, 07:50 AM
It's installed according to the instructions I have. I double checked. Don't know what to do.
Old 04-15-2007, 08:40 AM
Call Gadget at URD and make sure you have the correct instructions for your year truck.
Old 04-15-2007, 09:58 AM
I emailed them this morning. The instructions that Kevin sent me look correct. It was a fwd email right from URD for his request for instructions for a 00 CA emissions 4Runner with 3.4V6. I can't even drive it a mile without the codes coming back, so something is wrong.
Maybe they didn't send the correct simulator? I don't know if there is a diff with a CA emissions truck, which is what I have.
We'll see what they say.
J
Old 04-15-2007, 12:58 PM
They emailed me the instructions....same as what Kevin sent me.
Old 04-15-2007, 01:06 PM
montypower's Avatar
Remember your O2 sensors have to be installed and plugged in for this to work. Mine works great.
Quick Reply: URD O2 simulator install help
