U Joint ?'s
Old 05-01-2011, 07:12 PM
PitbullRescuer's Avatar
U Joint ?'s
Well, getting a nasty vibration under acceleration. I'm sure it's my u joints. Anybody done them on theirs? How much of a pita are they?
Also, I'm guessing Spicer joints are the way to go but I'm open to suggestions.
Thanks.
Old 05-01-2011, 07:33 PM
scottishb's Avatar
Welcome to the vibrating 4Runner club! I haven't done mine, but they look super easy.
Old 05-01-2011, 08:44 PM
justin_4runner's Avatar
there not too bad to do. just pull the shaft and do both front and back, about an hr or so to it.
Old 05-02-2011, 03:20 PM
jdmaccord6's Avatar
it's not horrible if you're not in really bad shape. i let mine go to far and the extreme vibration of the drive shaft actually grooved/chipped out the yoke and we had to cut off the joint. It would have easily been a 2 hour job tops if i would've replaced it a few months ago...
I also used napa joints in mine that had a zerk fitting. They all seam to hold up from what i read up on, just make sure it has the zerk fittings because there are cheaper ones that do not come with them.
Old 05-02-2011, 03:55 PM
ra33it's Avatar
You might want to get it balanced when you do the U's and toss a fresh coat of paint on there too...
If the vibration still occurs, you might want to also check your rear diffs oil level....
Old 05-02-2011, 04:09 PM
Bandido's Avatar
u joints really arent much of a pita at all, cost <20 a pop, ive done the rear joint in my 2001 and all the joints in my 94... can easily be done with your socket wrench and a bench vise...
but improperly balanced/ aligned tires can cause all sorts of vibration as well...
Old 05-03-2011, 10:42 AM
Tires are brand new. Balanced and aligned when I did them. Pulled it apart today, definitely the last u joint, it was in bad shape. Bought all 3 for the rear drive shaft. Pulled all the clips, rented a u joint press from Advance Auto, bent the press and broke the first cap. :banghead:
The drive shaft and the new joints are at my buddy's shop getting pressed out, new ones pressed in. Waiting for the call to go pick it up so I can put the Runner back together.
Old 05-03-2011, 10:47 AM
blake.nemitz's Avatar
all you need is a bfh and a vise. check your pinion bearing first my .02
Old 05-05-2011, 07:26 AM
Update: Got the drive shaft back from my buddy with all 3 joints replaced, night and day difference. Vibration under acceleration is gone and no clunking when shifting out of park.
I love this truck, it's a beast. Should crack 200K miles this summer.
A few pics for you guys:
Old 05-05-2011, 07:55 AM
J2F42C's Avatar
It looks great; one has to love the Imperial Jade color. I wish I had gotten Duras, my Revo 2s just aren't cutting it as well as their previous generation did.
Did you add some aftermarket springs/shocks to it? It looks as if there is a little rake there.
I love those houses; somewhere in the Quaker state perhaps?
Old 05-06-2011, 11:03 AM
Good eyes. Yeah, it has OME 906's in the rear with 10mm spacers, stock tall springs with 1/4" spacers up front. Bilsteins at all 4 corners.
I live a few miles outside Philadelphia, most of the houses on my street are 100+ years old. I love the area.
Old 05-06-2011, 05:05 PM
wyoming9's Avatar
Red face
I guess changing u joints all depends on what part of the country you live in.
I have had so much grief changing them I will no longer do them anymore.
I found it was cheaper to buy a brand new drive shaft with the time spent trying to get them out the last time.
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
4x4YOTA
08-23-2016 09:08 AM
crash813
09-27-2015 07:15 AM
Odin
09-26-2015 06:56 PM
Quick Reply: U Joint ?'s
