tri-way crossover
Old 03-03-2003, 04:39 AM
Churnd's Avatar
tri-way crossover
What do you guys think about this?
Tri-Way Crossover
It sounds like it would be perfect for my truck, as I want to run 2 component speakers up front and a sub in the back. This way I could use 1 amp instead of 2. The only downfall I could see is the inability to change the sub's gain and not the speakers'. But you want those to be the same anyway, right?
Old 03-03-2003, 09:08 AM
Churnd's Avatar
The crossover offers a 12 db/octave setting for the subwoofer and a 6 db/octave setting for the speakers and it handles 250 Watts RMS per channel, which is way more than I plan to be using. Is that match a good setting to play the speakers on? The cutoff frequency is set at 100Hz, and I know some of you set your subs to frequencies below that, like 80-60 Hz.
kawazx636
10-06-2021 03:03 PM
AustinTaco
09-18-2015 08:58 PM
sphealy
09-03-2015 07:55 PM
e_richard
07-30-2015 06:50 PM
93X-Cab Mon
02-23-2006 07:41 PM
Quick Reply: tri-way crossover
