transmission fluid leaking, sealant needed
I am slightly leaking transmission fluid from I think the front seal. Someone told me to try a sealant you pour in with the fluid, but I can't find it. Has anyone tried this before. It is a slight leak. Thanks for any help.
Location: Far western Kentucky (transplanted from central PA)
I haven't heard much good about leak sealant additives, especially for the tranny, and don't have any firsthand experience. I also suggest you stay away from them and recommend you have the leak looked at professionaly by a shop with a good history.
I have the same problem in my toyota motorhome. It has the 3.0, a '91. I put in some stuff but it didn't work... I believe mine is the front seal also... But it only seems to do it with the "overdrive" on... I'm not sure about that, but it hasnt leaked since i leave the "overdrive" off....
I am curious if that actually keeps it from leaking.. and believe me, this sucker will spit out some tranny fluid fast...
FS[PacNorWest]: T100 auto trans/tcase - Bay area, CA
94whiterunner
09-22-2015 07:25 PM
