TPS resistance values?
Old 04-14-2010, 11:58 PM
Cpate81's Avatar
Need help in getting the range values for a good tps. I am testing my tps (throttle position sensor) p/n: 89452-35030
I have two books, the FSM and Haynes. They give different resistance values between the terminals. One book says my tps is bad, and the other says that it is good.
Could someone please provide the following five different resistance values for this tps:
E2-Vta (open and closed)
E2-idle (open and closed)
E2-Vc
The tps is on my 2001 4runner, that is the four terminal type.
Thanks in advance!
Old 04-15-2010, 08:58 PM
Cpate81's Avatar
anyone?
Old 04-16-2010, 03:33 PM
Cpate81's Avatar
nobody at all???????
Old 04-16-2010, 08:15 PM
RandyÄ's Avatar
E2-Vc
Thanks in advance!
Just to make sure that we are on the same page let's map the terminals:
1 -- E2
2 -- VTA2
3 -- VTA
4 -- C
Casting numbers match yours.
I'm not sure which one you are calling 'idle'
For reference - FSM DI-266 and SF-28
This 4 pin TPS is a rare bird and I have never found a source for it. (which is why I have a throttle body sitting on my bench that I metered for you)
Here are the numbers @73F:
VC - E2 = 1.6k
E2 - VTA = 0.8k closed / 1.4k full open
E2 - VTA2 = 1.27k closed / 1.74 full open
If you need any more #s let me know.
Rerun
3.4 Swaps
10-01-2015 12:24 PM
Gone Fission
09-22-2015 04:51 AM
accuracy
09-20-2015 07:44 PM
Boomer8404
09-20-2015 06:15 PM
larrys93pickup
09-17-2015 07:05 PM
Quick Reply: TPS resistance values?
