toyota tranny swap
Old Nov 16, 2004 | 07:14 PM
bigbadktm's Avatar
toyota tranny swap
I am going to be in the market soon for another trans for my 98 toyota t100. its the 2wd 3.4l auto with the column shift. not sure on the model no. of the trans.
the thing is, i would rather have a manual trans as i do a lot of pulling up hills and such.
is the bolt pattern the same on the bell housing?
aside from a new pedal hanger, flywheel, misc cutting, and the man. trans, what else do i need/ look into?
do i need the ecu from the donor truck with the manual trans?
i would really much rather have a manual over the auto. i am curious if anyone has ever done this with a computer controlled tranny, and how it turned out. or maybe somebody has a hook up on a low mileage auto trans for cheap.
Old Nov 16, 2004 | 08:38 PM
kyle_22r's Avatar
generally speaking, toyota auto-to-manual swaps are pretty straightforward. the transmission from V6 T100 tacoma, tundra, or 4runner made after 1995 should be as close to a bolt-in as you can get.
the pedal assembly from a T100 with a manual tranny should bolt in place of your auto one
bellhousings between manual and auto are different
the hardest part will be hotwiring the neutral safety switch to trick the computer to thinking it's in "park" or "neutral" so the engine can be started. everything else should bolt right up
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
quaale94TRD
3.4 Swaps
Jun 23, 2015 10:27 AM
94more
Jun 19, 2015 01:55 PM
williemon
Jul 13, 2002 09:48 AM
