Throttle Position Sensor - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-16-2003, 07:38 PM   #1 (permalink)
Anyone adjust thier TPS lately?
I have been noticing that sometimes when I'm "into" the throttle it seems like when I lift off I get better responce. I have several items to check: the TPS, fuel filter, 3.0 engine etc. Well I typed in toyota throttle position sensor in the address line and lo and behold several hits came up. I checked my TPS and found I was at the upper limit so I adjusted it to mid-range (easy to do once I figured out how to get the probes on the pins) and set it to 506 ohms (range is 200 - 800 so 506 is fairly close )
I will test drive later but I did notice that there was a differece when I pulled into the garage.
Look here if you want more info: http://www.mpcfaculty.net/JOHN_KALIN...n%20Sensor.htm
Good luck
__________________
95 SR5 5sp Garnet Red, Bilstiens, Amsoil, synthetics in running gear, air bags in rear coils, silverstars, OME SS. Aisin hubs
TBI: Hella 550s, backup lights
SMT-5
donc is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Throttle position sensor jhksclemm The Classifieds GraveYard 2 03-22-2007 06:28 PM
Throttle Position Sensor ramrugby09 86-95 Trucks & 4Runners 7 04-06-2006 01:12 PM
Throttle Position Sensor Bassinfool 95.5-2004 Tacomas & 96-2002 4Runners 15 03-20-2005 09:22 AM
Throttle position sensor help 1987 street toy 95.5-2004 Tacomas & 96-2002 4Runners 7 12-16-2004 07:12 PM
Throttle Position Sensor lerence Maintenance & Repair Archives 6 08-22-2004 12:00 AM
2009 InternetBrands, Inc.
