| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Tacoma, Tundra and 4Runner can they be swapped?
__________________
1996 4Runner LTD
Rear locker (from factory) 3.4 V6 (running only the "good stuff" Valvoline Syn Blend and Carquest Wix Red Fitler (B241)) 214XXX Miles and counting Missing driver side clearance lamp (I'm not the only Yota in town like that theres 2 more and a Pathfinder!) Removed the plastic fender on the bumper Current Mods Flow Master 40 Brush guard Removed Running boards Futures Mods New Bumper 3 inch lift Driver side lamp |
#2 (permalink) |
I'm not sure if the Tundra is the same or not, but the Tacoma and 4Runner are basically interchangeable across the front end. My 4Runner is running all of the following Tacoma parts: Steering (rack and all links), spindles, UCA's, CV's and front diff. (even though the parts are interchangeable, they are not identical - the Taco steering and CV's are beefier than 4Runner stuff).
So yep you can put the struts for a Taco in a 4Runner.
__________________
'96 4Runner Ltd. Stock for now. 5" Tuff Country lift on order and rear leaf conversion - in progress. |
#3 (permalink) |
Tacoma will fit, same front end. Earlier tundras you can fit the strut and spring on a 4runner/taco. But a stock tundra spring and coil lifts a taco or 4runner, so a tundra lift on a runner is most likely going to be over kill.
What type of lifting you looking at?
__________________
97 4runner, 2.7 5speed 4wd, 5.29, 33 horns armor locked lifted heavy SOB broken front and rear swaybars My Profile.. |
#4 (permalink) | |
Quote:
Take a look at the Sonoran Steel site for some good info on 3rd Gen lifts if you have not already.
__________________
Lance 2001 4Runner Limited 4X4 -- 315/75R16 MT/Rs | MT Classic IIs | Dual ARBs/4.88s | (F) 5125/Tundra Coils (R) 5125/LC Coils | 4Crawler 1.5" BL | Aisin Manual Hubs | Slee Sliders | Sonoran Steel Rear Bumper | TJM T-15 w/ Warn M8000 2004 Land Cruiser -- OME Medium Lift | Nitto Terra Grapplers |
#5 (permalink) |
I just wanted to know was all.
__________________
1996 4Runner LTD
#6 (permalink) |
Yes the front struts and springs are interchangable, but the top plate from the Tundra will not work, you just need to swap your 4runner one. The Tundra and Tacoma have alot more shock options than the 4runner.
__________________
Why??? Because I Can !!! My wife knows the difference between a body lift and suspension lift!!!, does yours? 96 4Runner, E-locked, TRD Tundra/ FJ80 coils, Bilstien 5125's, 285/75/16 MTR's. Lots more custom parts coming. 87 Supra 1jz 420 hp Check out my website: www.bicperformance.com |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| a-arm compatibility? Tacoma, Tundra, 4runner | kallen | Offroad Tech | 0 | 05-21-2005 08:05 PM |
| Toyota 3.4l 4runner Tacoma Tundra Throttle Spacer | jc1kz | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 02-28-2005 03:21 PM |
| Tundra/4Runner/Tacoma Suspension | 03TundraTRD | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 09-20-2003 08:20 AM |
