Sway away shocks in need of repair - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-28-2004, 11:18 AM   #1 (permalink)
Mig750's Avatar
Send a message via AIM to Mig750 Send a message via Yahoo to Mig750
Cool Sway away shocks in need of repair
Yeah its been a long time since Ive been here but my baby is in need my sway-a-way shocks are shot. Its hitting hard and my 285 tires are rubbing now. Any one know if I can get them revalved or whatever it is they do to make them like new???????????
__________________
http://www.toyotaoffroad.net/jnburtman/migg_750.html
1996 4 Runner Dynomax muffler. Chrome Carryboy Mataburro (bull bar) Clear front crnrs KENWOOD W/CD/CASS,tweed seat covers with Toyota and emblem embroidered in material. Addco sways, Nuke Discos, OME lift in the rear, SAW up front
Mig750 is offline
Old 11-28-2004, 06:04 PM   #2 (permalink)
rowan's Avatar
yeah you definatly can, they have a liftetime waranty... just not sure how...
__________________
-Rowan
black 99 tacoma regular cab
2.7L 4cyl. 5spd, 4x4
4" lift front SAWs and Revtek Diff Drop | 4.5" lift rear Skyjacker AALs and Daystar Shackles | removed swaybar | ARB bullbar | 33x12.50 BFG ATs on 15x8 AR Outlaw II's | Bushwhacker Cut-out Flares | kenwood headunit, amp, 10" MTX sub | manual hubs | Rhino liner | K&N Filter | Delta tool box | Pro Comp Lights | sometime in the future maybe: armor, gear/lock? 35s? SAS?
rowan is offline
Old 11-28-2004, 08:01 PM   #3 (permalink)
turboale's Avatar
Send a message via AIM to turboale
Thats one of the biggest downfalls to the SAWs,
You have to take them out to get re-valved/redone... I might as well had to with my downeys, we ended up cutting the shock in half then putting the thing into a 12ton press. But, the downeys have a sleeve that fits over a bilstein shock so I only had minimal down time. Call SAW, you have to send them off.
If you losing that much ride height I don't think it would be as much the shocks as the springs getting compacted. My downeys are doing the same...
__________________
--Austin
RHaus NYC
06 M45 Sport - Beauty
96 4Runner - The Beast
turboale is offline
Old 11-29-2004, 12:12 PM   #4 (permalink)
rowan's Avatar
yeah i just got bigger tires and they rub a little offroad.. when turned and flexed. i dont want to crank my shocks anymore though really, my cv's are at a pretty high angle. the saws only have 20,000 miles or so on them now so still in good shape.
__________________
-Rowan
rowan is offline
Old 12-15-2004, 11:03 AM   #5 (permalink)
cvlighthouse's Avatar
Send a message via Yahoo to cvlighthouse
I think they have a 1 year warranty.
Can someone direct me to a link?
My collars are seized up and I can't adjust or remove my SAWs
edit found one:
http://www.yotatech.com/showthread.p...t=saws+collars
__________________
01 Taco TRD w/ cab over camper here: http://www.yotatech.com/showthread.php?t=116933
Replica Ivan Stevart TRD grille here: http://www.yotatech.com/f2/01-tacoma...-alike-136935/
cvlighthouse is offline
Old 12-15-2004, 04:59 PM   #6 (permalink)
SEAN_at_TLT's Avatar
Re-valving the shocks is not necessarily the answer. If your shocks felt too stiff or too soft out of the box then a re-valve would be the answer. But if they felt good and recently began to fell not so good, the problem is elsewhere. It is possible they just lost their nitrogen charge, sometimes people will deflate your shocks just to be a jerk, otherwise a slow leak can do the same. If your coil-springs have sagged more than just the initial settling then something is wrong with your setup. Eibach springs should never sag unless they are over-compressed. Eibach has charts available in .PDF format on their website that tell you the available spring-travel for a specific coil size. If you crank your coils too high not only does it damage CV's (as we all know) but it actually can damage the coils themselves by over-compressing them.
The first thing I'd do is check the nitrogen pressure and verify if it is up to spec, then if it is correct, it's possible that you damaged the shim-stack from slamming a few hard hits (bent shim washers). You do not need to send in your shocks for service and if the problem is not a manufacturing defect then it's not covered anyway. These shocks are actually simple to work on. I know it seems scary but it's really a cake-walk! You can even order shim-stacks and install those yourself easily. I would call Kartek and ask for Mike Arthur's phone number, he is a SoCal suspension guru and for a reasonable fee, he can help you choose an appropriate shim-stack. Then Kartek can sell you the shims and shock fluid so you can install them yourself. It is also a good idea to get new seals, might as well right? If any of you guys are feeling adventurous check out this Sway-A-Way rebuild/revalve article we wrote a few months ago. HERE
__________________
-Sean
Trails Less Traveled
SEAN_at_TLT is offline
Tags
85, eibach, lifts, nitrogen, pressure, revalving, rhino, seized, shackle, shocks, springs, sway, swayaway, toyota, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
2006 Tacoma TRD front suspension (Bilstein shocks / TRD springs / sway bar) P. Bauer The Classifieds GraveYard 1 04-15-2006 10:18 PM
shocks and sway bars on a sas? 88yotaboy Offroad Tech 9 06-12-2005 09:50 AM
Sway bar shackle repair... help please... YotaJunky 95.5-2004 Tacomas & 96-2002 4Runners 37 03-26-2005 11:19 AM
2nd gen IFS sway front sway bar, is it really important? Ilovemountains 95.5-2004 Tacomas & 96-2002 4Runners 17 07-29-2004 07:20 AM
2009 InternetBrands, Inc.
