swapping 96 to 99 axle differences
Old 05-21-2009, 11:25 PM
mrloyd's Avatar
I am swapping the front diff and rear axle from my 96 limited to my 99 limited. Both are limited and abs 4wd 3.4. I'm changing front and rear because the gear ratios are different otherwise I'd just do the rear. Anyway I like the 4.30 better and want the locker in my 99.
Question is, is there anything I need to look out for? Any differences or should everything just change over like I hope?
Thanks, jl
Old 05-21-2009, 11:39 PM
Fink's Avatar
As far as I know, as long as they are both ABS you'll be fine.
Should be a bolt-on swap.
Also, do a search for "3rd gen axle swap 96 99" and see what you get.
There should be some good reading for you in there.
Fink
Flying91
45
04-11-2024 04:39 PM
icentropy
09-16-2020 02:47 PM
jerusry
10-19-2015 05:28 PM
deepmarsh
08-06-2015 03:44 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: swapping 96 to 99 axle differences
