steering wheel has quarters in it
New here with an interesting prob.
I just got my 96 runner yesterday. i new it had a few probs when I bought it. I searched and searched, over 500 threads and couldnt find anything. I did however, find all the info needed to get me where I'm at now!!
basically when I turn the wheel 1/4 turn either direction, its sounds like something is rubbing and there is loose change in there!!! Today I used info from these threads to remove every thing on the collumn. I couldn't get the shaft to come out though. While i was pulling and pushing, i must have popped something into place or something. i thought my problem was due to the wheel not locking. i came to this conclusion cuz it locks now and the sound is gone.
my Q is, has anyone ever had a prob like this? Should i worry about its return? I am not new to funny noises on lifted vehicles, but it drove me nuts the few times i drove it.
lemmee know
thanx
PS I have 2" BL and a tilt collumn
lemmee know
thanx
Ok its not his CVs becuase it was a noise from inside the cab in the steering column. It sounds like the little cam thingy that locks the wheel when the ignition is off was out of position. If you have the covers all off I'd take a careful look at the area from all angles looking for anything thats loose or not bolted/ screwed down all the way. If this is all good carefully reinstall the covers and all should be good. You might want to avoid locking the steering wheel with the mechanism under load ie when you are parked with the wheels turned into the curb at full lock and you have to strain the wheel over that little bit more to get the ignition to lock.
edit: something else you might want to have looked at is the universal joints in the steering column... I think there are three... one at the tilt wheel... one at about the mid point of the shaft and the last at the steering box. All of these are subject to wear and can become loose, requiring replacement.
If they fail while on the road... RIP.
Hope this helped Aviator
terminator
07-27-2015 07:13 PM
