Staun Tyre deflators
Old 10-07-2003, 07:36 AM
Gadget's Avatar
Originally posted by ravencr
Gadget, I've been airing down to 18-20 psi, and I was wonderig what some other people air down too on the trail? I've heard as low as 10 psi, but I'm scared to damage the aluminum rims.
Chris
I usually go 15 PSI.
I had a bit of trouble making it up impossible hill at Paragon in the driving rain. The trail guide asked me what my tire pressure was and then he said I would of made it up if I aired down to 10 PSI.
My plan is to stay at 15 and get another set of deflaters and set them to 10 for the next time I go to impossible hill...
Gadget
www.GadgetOnline.com
Old 10-07-2003, 07:45 AM
WATRD's Avatar
I usually start at 15 and work up or down from there, depending upon the conditions. In soft snow or sand, I go as low as 4 PSI and in mud I am pretty comfortable down around 10 PSI.
How much to air down is subject to several things, stiffness of your tire sidewall, width of rim and tire, terrain, etc. You will have to experiment with your combination to find the pressure to run for the conditions.
Old 10-07-2003, 05:25 PM
ravencr's Avatar
I'm running the 285 revos with a D load rating, and I'm not sure if that equates to sidewall strength or not. 18 seemed fine this past weekend, and this weekend I'll try 15 to see.
Chris
Old 10-07-2003, 05:35 PM
Flygtenstein's Avatar
I have Stauns.
They are set at 12 PSI but some times the valve is screwy.
I like them alot and would not hesitate to get them again, or encourage someone else to get them.
I like to stand still when airing down to talk and BS. No need to be in a hurry at the trail head and start driving away.
Airing down makes the trail a lot smoother, the traction a lot better and the trip more fun. Drop the pressure and see what happens. Worst case, you lose a bead, stick on the spare and get going. If you don't have a spare and a jack, you should not be on the trail.
Old 10-07-2003, 05:40 PM
  #25
sschaefer3's Avatar
I have the Oasis kit and have used it for the last 3 years. No problems. I'll get a kit here shortly for the FJ-62 as well.
They are set to 14.
Old 10-07-2003, 09:57 PM
  #26
SkyRat's Avatar
Has anyone tried EZ Deflator ? This seems like an alternative, though totally manual, way to go.
Old 10-07-2003, 10:13 PM
  #27
cabbage's Avatar
I was considering those too! But I saw them at: http://www.4x4groupbuy.com/currentGr...?productID=425
Old 10-07-2003, 10:26 PM
  #28
XtremeOff-Road's Avatar
My personal opinion, and this is just an opinion. Staun Tyre Deflators and a CO2 system and you are off an running...Seems to me that there are products out there that are making this more difficult than it needs to be...Why remove valve stems or hook all 4 tires together to deflate??
Again this is my $.02
Mike
Old 10-07-2003, 10:39 PM
  #29
SkyRat's Avatar
Mike,
SOLD!
We all like your shop and value your contributions here.
How about a group buy on these great deflators? There seems to be some interest here. I am in!!
Old 10-08-2003, 02:00 AM
  #30
ravencr's Avatar
I'm in on a group buy!
Chris
Old 10-08-2003, 05:47 AM
  #31
cabbage's Avatar
Me Too!! Group Buy! Group Buy!
Old 10-08-2003, 06:05 AM
  #32
Senior Member
jacksonpt's Avatar
OK, lots of good comments on these things. I'll be buying a set, group buy or not.
Old 10-08-2003, 06:36 AM
  #33
LOL you guys are nuts
Let me see what I can do for a group buy for you
Mike
Old 10-08-2003, 07:08 AM
  #34
H-man's Avatar
i have the stauns too and other than the small trouble of setting them (mine are at 20#)i love mine and have never had one not shut off when it wasn't supposed too so i would recomend them as well
just my .02 worth
good luck!
Old 10-08-2003, 07:59 AM
  #35
Mad Chemist's Avatar
I'm up for a group buy on the Stauns as well....
Old 10-08-2003, 08:11 AM
  #36
A group buy on a $50 product so that you can get it for what, $46?
The ones that deflate, but do not have a set value are decent, but you have to keep checking. At $10 for a set of 4, that is not bad at all.
Old 10-08-2003, 08:21 AM
  #37
TStango's Avatar
Even if it's just to save a couple of bucks, there's something about a group buy that get's people motivated to buy things. Did I mention that I'm in as well?
Old 10-08-2003, 08:36 AM
  #38
SkyRat's Avatar
I am going to buy these Staun Deflators.
If we can save a few bucks, be better equipped for wheelin', involve others and support businesses that support us so much the better.
Old 10-08-2003, 08:40 AM
  #39
SkyRat's Avatar
If you have a CO2 setup I would agree. If you over-deflate tires #2, 3 & 4 while checking pressure in tire #1, then you have a hassle to get the pressure back where you want it.
Old 10-08-2003, 07:36 PM
  #40
alanh's Avatar
Since I just ordered a set of deflators from Mike at the regular price a few days ago, I don't want to see any group buy that results in much savings.
Where you really would like to save some bucks is buying all the stuff that it takes to put the air back in that you let out. (Unless you want to get some exercise by getting a cheap hand pump and using that, or mooch off someone else.)
Alan
Quick Reply: Staun Tyre deflators
