Should I replace TRD with a magnaflow?
Originally Posted by MY024runner
btw I have the stainless magnaflow. Is your trd pipe stainless? I wanted Stainless pipes too but I have the reg. factory pipe and wanted to match.Just wondering?
i was looking at 4" round mufflers at magnaflow's site and i have a question for y'all....
do i want a muffler with a 2.5" core or a 2" core???
both mufflers are stainless steel, with 2.25" inlets an outlets, and 14" long. i would imagine that the core means the diameter of the mesh piping that runs through the middle. by having a smaller core diameter does that force more exhaust into the fiberglass? and does that make the exhaust note louder, quiter or deeper etc..... and what about back pressure???
Ok so thats like ten questions any exhaust guru's know what is ideal, should i try emailing a rep from magnaflow?
thanks ahead
thanks ahead
thanks ahead
thanks ahead
#26
thanks ahead
thanks ahead
The correct muffler to get is listed on my exhaust site, and they are not round.
#27
anthraciterunner let me know how you like the magnaflow.
#28
Originally Posted by anthraciterunner
Will do. I looked up california muffler and gave them a call. They are expensive so if you ever need work done, don't go there. Also, king muffler said they wouldn't do stainless piping. The place I found can do mandrel bends and ss pipes too. I will let you know the quality of work when it is done incase you ever need to replace your system. I'll take pics of the tip if I can and if I can figure it out, I'll get a clip made. Thanks for the suggestions MY024runner and I will definately let you know how it turns out. He ordered both the 14" and 18" so I could test and choose. Does yours rumble at idle? What about when you gas it?
#29
Originally Posted by Corey
I do believe you are looking at the "rice style" of Magnaflows lke you "hear" on import tuner cars.
oh gosh no! i am not trying to get the rice style fart can that sits out the back! i was just thinking that since my current muffler is round that a new muffler would fit best in the stock location if it was round also. And i do not want it to be too loud, i just want a nice deep sounding muffler. ( I was reading through the Magnaflow FAQ section and they said that a round or an oval muffler sound exactly the same, the only difference for sound is volume)
My confusion was about the core diameter, they listed two different sizes; 2.5" or 2", the part #'s are 14415 and 14445. I assume that the core diameter means the size of the vented pipe that runs down the middle of the inside of the muffler. does anybody know what size is best? There is no core dia. listed for anthracite's....
anthraciterunner:
I am wondering what size you will decide upon, the 18" or the 14". I compared the volumes of your 5"X8" oval to the volumes of a 4" round and a 6" round. the 6" is closer to the 5"X8" but since you have a V6 and i have a 4 banger i figure that the 4" round is better suited to my needs. But I am hoping to gauge the length by your judgment. let us know! thanks a bunch!
#30
anthraciterunner:
anthraciterunner:
#32
Got my muffler and tip replaced today. Both parts by magnaflow. I decided to go with the 14" and it sounds awesome. They let me listen to both and the 18" was just a little louder than the TRD (in the cab). I went with the louder one because it was not as obtrusive as I thought it would be inside and it is actually quite pleasant. The sound is most apparent between 1500-1900 and it is a low, deep growl. I was told it would mellow out a little as the glass loosens up inside the muffler. The tip was a double wall, 3" diameter outlet/ 2.5" inlet/ 7.5" long. If anyone wants to hear a clip, let me know how to do it. ( yeah, i'm a litle ignorant in that department). I have a canon digital camera I can use to take the clip.
#34
I have a 24" body Magnaflow in my truck and I love it. From what i've read in this and other forums is that guys who get the shorter mufflers end up changing them because they are too loud and drone too much.
The 24" is what you should have gone with.
#35
Originally Posted by kevin444
Just got a Magnaflow 18" 5x8 Installed today. Sounds kinda wierd. At low rpms it still kinda drones.. =/
When I start moving and I'm at the lower RPMS you can hear the growl.
Loving it
06-01-2021 01:51 PM
TURBOrunnerNM
07-22-2015 11:01 AM
