shoot me... I need some help.
Old Nov 8, 2004 | 10:04 PM
OneTrickToy's Avatar
So, I just swapped my timing belt. Boy was that a PITA!!! The crankshaft pulley bolt would NOT come out. Not even with a 1/2" impact gun. I had to have a big bar of heat treated steel drilled(then I cut the thing in odd places) to bolt to the pulley and hold it still while I put all my strength into that bolt. So anyway, I got the thing apart, put the new belt on, cranked the motor by hand several times to make sure the timing marks stayed lined up. Everything looked good. Put it all back together and filled the radiator. Started it up and let it warm up, expecting it to suck in the coolant from the radiater, but it wouldn't. Now, I didn't bother swapping out my water pump because I didn't want to screw with something I knew wasn't broken. My 3VZE has always run really cool. What could be going wrong? My waterpump wouldn't just coincidentally die when I changed the timing belt woult it?
Old Nov 8, 2004 | 11:27 PM
jimbo74's Avatar
in your rush to put everything back together quickly forget to put the accessory drive belt back on?
no, im not flaming you if you did, just the idea came to mind from prior experience
Old Nov 9, 2004 | 03:24 AM
HondaTec521's Avatar
Did you let it warm up? The thremostat has to open first .Let it idle until it warms up keeping an eye on the temp. guage(dont let it get too hot).I also use a funnel in the radiator neck to raise the coolant level above the highest coolant passage/hose in the engine compartment.I hope you put in a fresh T-stat(factory) while you were in there.
Old Nov 9, 2004 | 08:23 AM
Nathan Buchanan's Avatar
You can get that crankshaft pulley bolt off by putting a socket on it with a cheater bar and putting the bar against the frame rail. Unplug your wire from the coil, and crank on the starter, The bolt will come right out. I didn't explain that very well, but you get the basic gist of it. I did it that way on my 22RE, anyway; and it worked great.
Old Nov 9, 2004 | 11:27 AM
Already got the bolt off.(read above). No I didn't touch the thermostat. All belts were installed correctly with the apropriate tension. Is there something I need to do to prime the waterpump???? I let it run for a bit to have it warm up/open the thermostat. It didn't open where it usually does. It really seems like the waterpump is working but it worked perfectly before hand....
jb451
7
Oct 7, 2022 06:58 AM
zytra
Jan 24, 2019 03:16 PM
bradahman
Oct 1, 2015 09:24 AM
Shagool22
Sep 28, 2015 07:53 PM
LotOMiles
Sep 14, 2015 11:45 PM
