| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
setting tdc
#2 (permalink) |
Staff
not sure what you are asking. If you are wanting to make sure TDC of the engine matches the 0 deg mark on the timing mark: You install a piston stop (to stop the piston from coming all the way up). Turn the emgine slowly until it touches the stop. Then mark where the timing mark is in the damper. Then turn the engine the other way until it just toughes the piston. Mark the damper again.
If the damper is correct (not slipped), both of your marks wii be equal distances on each side of the factory mark.
__________________
David TLCA 14788 71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap. 76 Landcruiser FJ-40 project/parts (haven't decided) |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Any way of knowing if I'm at TDC? | benwahballs | 86-95 Trucks & 4Runners | 7 | 02-17-2007 10:11 AM |
| TDC or not? | 4runnerD | 86-95 Trucks & 4Runners | 14 | 02-14-2007 09:11 AM |
| How to find TDC? | rcm3 | 86-95 Trucks & 4Runners | 3 | 07-25-2006 06:25 AM |
| Setting TDC with valve cover off???? | Saint_Berzerker | 86-95 Trucks & 4Runners | 13 | 03-26-2006 06:33 PM |
| setting tdc | Jakub | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 09-07-2004 10:43 PM |
