Same drum size between 15" and 16" wheels?
Old 07-27-2009, 06:10 PM
Smokey's Avatar
So I've been fighting a wicked tire balancing issue (as confronted by many others)... So after 6 re-balances at 3 different shops (2 indys, 1 dealer), I am concerned that I may have other suspension related issues.
To rule out the tires and rims, my buddy is willing to let me borrow his 2000 Tacoma to swap his wheels/tires onto my truck. I'm not 100% sure, but I think he has 15" rims (15" was the standard size, correct?). My 02 Sport has 16" wheels.
So my question is this...if the Taco has 15" wheels, will they fit over the drums on my 4Runner so I can do a road test? I did a quick search on Napa and there are shared part numbers between the two, but I want to make sure.
As always thanks for the info,
Chris
Old 07-27-2009, 06:49 PM
Elton's Avatar
15'' rims will not clear the calipers
Old 07-28-2009, 04:18 AM
Smokey's Avatar
Not worried about the front....the vibration I'm chasing is in the rear. So I'm only looking to swap out the rear tires.
Old 07-28-2009, 06:33 AM
Jay204's Avatar
Just did a caliper conversion from 16-15....the 15's will fit over the drums in the back no problem.
Old 07-28-2009, 08:05 AM
Elton's Avatar
hmm i thought you where trying to swap out all 4 but they should clear the drums just fine then
Old 07-29-2009, 08:38 AM
Smokey's Avatar
Thanks Jay, good to know. FWIW, I finally found a local shop that has a Hunter road force balancer and the adapter to properly balance my tires and that seems to have solved most of my rear vibration issues. All 4 tires passed the road force, but they found all 4 tires to be out of balance -- surprise, surprise.
Next up are the shocks (maybe the complete SS 3.0 system) and hopefully that will smooth out the constant bounce over the smallest bumps.
Thanks again!
justdifferentials
Just Differentials
08-15-2015 05:25 PM
PopsDad1
07-30-2015 02:21 PM
coffey50
07-28-2015 10:55 AM
Gravel Maker
RuffStuff
07-27-2015 06:53 PM
Yotoder865
07-09-2015 07:51 PM
Quick Reply: Same drum size between 15" and 16" wheels?
