Rear Locker for my Surf/ 4runner: Need help
Old 10-16-2008, 08:52 AM
sajidd's Avatar
Guys,
I am completely non technical, and need some serious help here. Would like to install a rear electric or mechanical locker on my 1996 Surf (4Runner) fitted with 1kz diesel engine.
Any recommendation?
The electric ones, mostly from ARB are way out of my budget. SO what are my other options. Pls help and advise.
Thanks
Sajid
Old 10-16-2008, 09:06 AM
scuba's Avatar
Aussie lockers are a great lunchbox locker so i have heard.
Although if its a daily driver a selectable locker would be much better.
Do some searching buddy, its your best friend
Old 10-26-2008, 04:13 AM
hazza0224's Avatar
yer if your on a budget get a minispoul diff (spelling?) cheap but always locked and you will shred tires going arround corners.
Old 10-26-2008, 08:56 AM
Gerdo's Avatar
Go with an ARB. I don't know what model you need but I'm sure they make one that fits. You Then will also have onboard air. Selectables cost more but are worth it.
Old 10-26-2008, 09:02 AM
Belize Off Road Team's Avatar
1996 Surf, look in the junk yards for factory ones. normally came on SSR-G and SSR Limited Surfs. make sure if you do to take all the electronics that go with it.
Old 11-02-2008, 09:57 PM
chad99's Avatar
I got a lock right in my 4runner....you always know its there....just have to know how to drive with it to prevent/reduce the lurching during turns...IMO if you are going to do any street driving then no to the spool...lock right is very livable and of course air locker is the best but if your on a budget the lock right (lunch box) locker is the only way to go....unless you are able to find a used stock locker for a good deal...and even if you do you might have to regear it.
06-01-2021 01:51 PM
Ironmike4x4
02-03-2016 11:13 AM
jerusry
10-19-2015 05:28 PM
Daneums
08-20-2015 05:36 AM
jaretstuff
08-04-2015 02:08 PM
Quick Reply: Rear Locker for my Surf/ 4runner: Need help
