Rear Differential problem?
I have a 1996 Limited 4Runner with 193,000 miles almost problem-free driving. I'm a single female and don't know a thing about fixing my 4Runner but it sure has gotten me to and from work in some fierce snowstorms.
I suddenly started having a problem driving on an interstate last weekend and looking for confirmation that the mechanic has it right when he says it's a $1500 repair for the rear differential.
1. Stuttering, small jerks when I slowly apply acceleration from a stop. After several stutters it moves smoothly.
2. Coming off the interstate to a rapid stop:
a. I stop and then accelerate. It appears to be in neutral and the engine races. It then suddenly does a big jerk with a loud thunk noise and it suddenly moves forward smoothly.
b. I stop and the thunk/jerk happens just as it comes to the full stop. At this point my foot is on the brake and it is really a loud thunk and the car jerks slightly forward even with foot on the brake. The sound comes from the rear end.
3. I did have have the jerk/thunk happen 2 times coming to a stop at lower speeds 35-45 mph. Generally driving at lower speeds around town with slow, gentle stops it never happens. There are no noises at any other time.
At $1500 for repair I want to be sure it's been diagnosed correctly and it is worth fixing or if it's time to sell. I'm moving from MI to KY and don't need a 4 wheel drive but love my 4Runner.
Also, I did have the strawberry milkshake 13,000 miles ago. The mechanic really flushed the system until it was crystal clear and says this is not a transmission problem.
Hmmm... Idk... sounds like a tranny issue to me. If the engine revs, then suddenly jerks, and takes off... Its unlikely to be the rear diff. If the rear diff was that bad, you'd have heard some nasty noises coming from it, and it wouldnt just jerk, and work fine.
Strawberry milkshake in the trans, is never a good thing, especially if you dont how long it was in there.
second opinion for sure.
if you had a friend that could remove the rear driveshaft, put it in fwd and test it in front wheel drive.
i think it sounds like tranny problem too.
It is easy/cheap enough to remove the third member to make sure. perhaps you want to ask him to take out the third member for a visual inspection. The third memeber is the part of the drivetrain at the end of the driveshaft. It holds the gears in the axle housing. Of course it costs some money to remove and inspect the third member, but for the cost of a visual inspection of the gears it is worth it if you are unsure. If the diff is the propblem it will be obvious visually. Maybe he can waive the charge for the inspection if you give the job to him.
Also, it is hard to find a good diff guy. It is difficult work. Take a look at Eastcoastgear.com. They sell fully built third members that any mechanic can install
If you fix the diff, pay for new bearings while you are in there. If you get a new third member from east coast gear it will have new bearings already.
Sounds more like a trans issue to me too but that's easy for me say over the internet. If he is sure it is a rear diff, ask him to waive the repair cost if a new rear diff does not fix it.
Good luck, sounds like it won't drive much longer if it is a rear diff issue.
PS many times a rear diff proplem is the result of low gear oil, low gear oil is often the result of leaking axle seals/clogged diff breather.
Thank you all for your thoughts on this. I have no idea if the axle seals are leaking. I think the $1500 was a rough estimate for a total repair. I'm going to take your comments in to him and ask him to reconsider if it could be transmission or to check out your suggestions for checking for axle seal leak or ways to check the differential. I haven't found any information that this is an expected issue for this vehicle.
I just had thunking/thumping noise, I greased my slipjoint/zerk fittings, and not a single problem since... not saying that's your problem, just my two sense
My problem was everytime I was coming to a stop thud thud thud!
Heres a quick comparison of what you pretty much said, and she pretty much said:
My rpms raise without the vehicle moving briefly. So after I greased my zerk fittings that fixed my problem,,,, Follow?
Exaggerated comparison for fun:
My engine blew a piston thru the hood. After I changed my oil that went away.
This is fun,,, we should do this again some time….
My old Tahoe done the same. Cleaning and putting fresh grease on the slip yoke fixed it. Common for auto transmissions with slip yokes
I had an automatic trans do something like this.
I was pulling the trans the person I sold it to said it worked just fine.
I also pulled the third out. It all looked good no chips nothing loose .
Never did find the problem.
Increasing rpm sure does not sound like a differential problem but you not going to know till it gets pulled out.
Instead of filling this thread with comments like that just stay out of it, no one is making you post.
there are no grease zerks on a slip yoke.
That was the fix for the clunk when coming to a stop. I didn't say it was a fix for all the problems the PO was having.
Deleting post because this thread is old and wtf was it revived to argue about zerks for...
Let me explain something to you,
Nobody is arguing about the fact that theirs zerks on slip yokes. Im fully aware of the date on this thread. This thread is not that old and it wouldn't matter if it was.
I'm aware of what zerks are for and why they are not her problem. My point is she has certainly made a decision 3 months later and bumping an old thread to argue is silly.
Guess you just are 'that guy'
So is jumping into an old thread and calling people silly. Your silly….silly! Maybe slim slay would slough a slumber sausage and slue would or should sue some slippery sanatizational sanches sack of potatoes?
That will stop to your attitude pretty speedy like uh…who's silly now.
