Last edit by: IB Advertising
- Toyota Tacoma How to Change Rear Axle Seals and Differential Fluid<br>Step by step instructions for do-it-yourself repairs.
Rear axle seals fail after switching to Synthetic Differential fluid
how could the rear seal failing warp the F rotors??? i already had that issue
ive been using synthetic in the diff for over 100k (@ 173k) and just had the first? RR axle seal leak.
When the rear seals leak, they essentially lube the rear shoes eliminating any rear braking action. So in order to stop, all the braking falls on the front brakes. The additional heat buildup is what causes the front rotors to warp.
jerusry
10-19-2015 05:28 PM
