Question on tacoma a/c (evaporator & expan valve)
Old 05-29-2003, 01:34 PM
toyotafan's Avatar
If I have a pretty major leak in either my expansion valve tube (inlet or outlet) or in my evaporator, would this be a possibility why my compressor doesn't kick on when I try and and charge the system. I'm thinking the compressor will shut off, if it isn't getting the necessary freon/oil. Just looking for a confirmation from someone with more experience. Thanks!
Old 06-24-2006, 05:44 PM
straightpipemike's Avatar
I have the same leak. It seems to be in the tube running from the control valve to the hose on the low pressure side. I haven't pulled it apart yet but my guess is it wore a hole in the tube where it passes through the firewall. I'm trying to locate the parts. I'll re-post if I get it fixed in the next few days. Good luck
smthwsn357
05-01-2024 07:28 AM
MO transplant
04-23-2023 11:58 AM
thefishguy77
07-30-2015 10:59 AM
Cplmike
07-08-2015 08:47 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: Question on tacoma a/c (evaporator & expan valve)
