Power steering Squeal
I just got a 2004 Tacoma TRD V6 and noticed the power steering is squealing mainly when I have the wheel turned all the way to the right or left but sometimes when I just turn it.I tried to search the forum because I figured someone has ran into the same issue as me but didn't have much luck. So any help would be greatly appreciated.
Thanks
Thanks
Check your belt and make sure its in good shape. The squeel is usually caused by a belt slipping, either because the belt is worn or your pump is sticking making the belt slip on it.
delmert
09-30-2015 04:34 PM
