Poor gear engagement when running--no problem when truck is off
Old 11-29-2012, 08:03 PM
HighLux's Avatar
Originally Posted by ThatGuy1295
Would you stop repeating yourself. I know what your saying.
Dont think just because you dont make any sense, that someone read your post wrong. Gees..
Makes perfect sense to me. I suggest you re read what he said. Try and understand it, before "engaging" your mouth clutch.
Old 11-30-2012, 05:15 AM
j2the-e's Avatar
Old 11-30-2012, 05:32 AM
j2the-e's Avatar
To the op,
If your hydraulics check out, and I suspect they will, since its all new stuff, you'll need to pull the tranny. When you're in there, check for oil leaks as well. If the trans input is leaking oil onto the disc it can also cause your symptoms. Also sounds like you need a clutch flex hose since its leaking, but thats not likely to cause your issue unless you run it empty
Old 11-30-2012, 06:33 AM
blake.nemitz's Avatar
Originally Posted by j2the-e
Just thought of something else. Have you checked the clutch pedal bracket? They are notorious for cracking
^^^this
Old 11-30-2012, 06:34 AM
  #25
most of the time if the slave and master are fine and youve got a lot of miles its the bracket,
Old 11-30-2012, 10:37 AM
  #26
ThatGuy1295's Avatar
Awww its cute. Your chiming in without actually reading all of it first. I wouldnt recommend it.
Im not gonna say anymore. All one needs to do is read the whole argument to see what your missing. Your idea would work great, if a seized throwout bearing was cabable of transfering enough torque to even effect the engines rpms. WHICH ITS NOT. The inside race of the bearing would spin on the input shart if the bearing was seized.
Old 11-30-2012, 11:36 AM
  #27
j2the-e's Avatar
Why is this so hard to understand? I'm not saying that the pilot would change the rpms. The rpms would change when the load is released from the engine. The test I described was to determine if the clutch is releasing or not. He never said if his clutch is releasing so we don't know. When at a stop the trans input should not be spinning. If it is spinning, because of a bad pilot or oil soaked clutch, it will be difficult to shift. And yes, the pilot bearing could easily keep the input shaft spinning. Hardly any torque required to do that when in neutral or when shifting.
Old 11-30-2012, 02:57 PM
  #28
By seized, I mean its not spinning as easily as it should, not necessarily completely seized up like its welded together. The clutch can still disengage if the pilot is seizing, however the input shaft on the trans may continue to spin, causing difficult shifting. It's unlikely that a faulty pilot bearing will transfer the full torque of the engine to the trans. So, to test for clutch dis-engagement, go about 30mph in second gear and push in the clutch(while still on the throttle). If the engine revs, clutch is disengaging and I'd be checking the pilot bearing. If the engine does not rev, clutch is not disengaging and you'll need to check the hydraulics.
__________________
Lets say his clutch is not disengaging, and when he's going 30 mph and pushes in on the clutch while still on the throttle, and the rpms don't raise up. That would reveal that the clutch is not disengaging just like you said. How in heck did he get the truck into gear in the first place to do this test? Or shift gears for that matter? Or stop without killing the motor? Or better yet, he already knows the clutch isnt disengaging, he just doesnt know why. He just needs to verify the hydraulics are working properly, and the "clutch pedel bracket", and if their all good then get a new clutch. The clutch basket can also go bad and cause the clutch not to release, by it not releasing doesnt mean its definitely hydraulics to blame either.
Old 11-30-2012, 03:42 PM
  #29
AVAUG82's Avatar
Seriously. If you push in the clutch and engine revs WITHOUT any problem, the clutch is disengaging and the hydraulics are most likely fine. If it doesnt rev like it normally should, or the truck inches forward with the clutch depressed, the hydraulics ARE NOT good. OR the clutch is bad. Yes, this test only verifies some part of the clutch system isnt working. BUT doesnt it also make it a valid test? Pull your guys' panties up. Seriously. If there arent air bubbles coming through when the system is bled, and the clutch is engaging, then the hydraulics are fine. MOVE ON TO SOMETHING MECHANICAL. I.e. Clutch fork, throwout bearing, or clutch.
Old 11-30-2012, 04:06 PM
  #30
I never pulled mine down, was I supposed to have?
If it were bad enough to feel it inching forward you would never be able to get it into gear, ever. Come on!! You guy's are all missing this. If the clutch is draging bad enough to notice it through rpms , or inching forward when in gear, then its not going to go into gear to conduct a drive test. In fact we dont need a drive test at all. The mechanic shop doesnt do it, the dealer doesnt do it, and they fix millions of clutches every year without having to drive them first. In fact since we have been talking they probably have fixed 500 clutches. Road test's are ok in some situations but theres more variables then what are being discussed here. You cant just say (if it doesnt rev its this part for sure) im not gonna admit thats a applicable test in this situation. Sorry.
The OP doesnt need to go threw all those steps to figure out weather its hydros or clutch.
Old 11-30-2012, 04:16 PM
  #31
j2the-e's Avatar
Seriously? You just love picking on me don't you? You can start the truck in first gear and I don't know about you but I can easily shift throughout the gear range without using the clutch at all. Pretty easy to do if you know how to drive a stick. And the op never said his clutch wasn't releasing, he said it was tough to shift. When I'm working on a vehicle, I like to determine exactly what failed and why in order to prevent the same thing from happening again.
Old 11-30-2012, 04:20 PM
  #32
You cant put it in first gear while stopped without a clutch their bud.
Old 11-30-2012, 04:35 PM
  #33
j2the-e's Avatar
You can if its not running
Old 11-30-2012, 04:46 PM
  #34
If you need to do that, then you have already solved the case haven't you?
Yup I had to start it in gear to find out I couldnt put it in gear while its running, huhu,
Old 11-30-2012, 04:49 PM
  #35
Ya im going to hammer on my transmission to diagnose the problem, would you want a real auto mechanic to do that to your truck?
Old 11-30-2012, 05:19 PM
  #36
AVAUG82's Avatar
Have you even ever drivin a truck with a manual transmission? If the truck is inching forward with the pedal all the way to the floor, it means that the clutch is either very worn, or the hydraulic pressure isnt enough to fully mate the clutch plate to the fly wheel. And youre right, the mechanics shop nor the dealership does not do these tests, but they have REPAIR MANUALS and have gone through extensive traininig which the OP obviously hasnt. Yes, if I had his vehicle here, I could diagnose and fix his problem without driving it just by having a good manual and common sense. And youre missing the point. That test would only tell you that you are having clutch problems in general.
Old 11-30-2012, 05:27 PM
  #37
AVAUG82's Avatar
So yes, youre right. The test is pointless, but it is still applicable. Just not in this situation. If I was the OP Id CHECK EVERYTHING RELATED TO THE CLUTCH, and if everything looks like youd expect it to, flush out the entire clutch system, then bleed readjust it. I say this because it is a very low dollar fix. If that doesnt fix anything, just get a new clutch kit since youre going to have to drop the tranny anyways to check throwout bearing, clutch, etc.
Old 11-30-2012, 06:18 PM
  #38
Worn clutches grab less. Or not at all. Their not stuck grabbing all the time. And yes I have only owned manuals, lots of them. And rallyed the piss out of them to boot.
Old 11-30-2012, 06:43 PM
  #39
HighLux's Avatar
Not gonna feed the troll.
Old 11-30-2012, 07:02 PM
  #40
j2the-e's Avatar
I am a real auto mechanic. No hammering required. When the engine is at the right speed, the synchros do the rest. That's how they are supposed to work. My original intention here was to determine if the shifting issue was because of weak hydraulics or a spinning input shaft. Either of which can cause difficult shifting. Apparently you are not a real mechanic since you don't understand the difference. Yes, this is a test I have done. And after this has been determined, the next appropriate step can be taken. I don't have the luxury of throwing parts at my customers cars. And I wouldn't tell anyone on this forum to do that either. I am here to learn and to share what I already know based on my experiences as a tech
Quick Reply: Poor gear engagement when running--no problem when truck is off
