Pinion bearing failure
Of course a used diff (setup by Toyota) you know was set up right, whereas the shop could screw up the rebuild. I know one guy on here blew a new set of gears because the shop didn't set it up right. You just don't know if a used diff has seen abuse.
Nelson, you have some good points.. If I decide to go w/ a rebuild it won't be through the stealership!
Dealership just quoted me $3300!
$1700 for the diff. work to replace the bearings, and then on top of that they said that I needed to replace the diff case because the entire thing was rusting/rotted out. I've sprayed my undercarriage w/ the rustproofing for the past 3 years too.
I'll take a pic and poste it to see what you guys think of it.
$3300 just isn't in my budget! Stealership is an understatement!
It would take some serious rust to make your carrier non-functional. I had to swap out my whole rear axle because it had rusted through, but my diff is still in functional order. It is rusty for sure, but it was smooth as butter right up until I pulled it out. I plan on cleaning it up, painting it, and putting it back in.
See if you can find a shop that can setup a diff and see how much they will charge with an order of new gears and bearings. Should be significantly less than $3300.
http://www.inchwormgear.com/store/pr...products_id=38
I just had my rear rebuilt. The diff guys said they knew what they were doing and I really do think they did. But they just had a real hard time getting my diff set up.
If this is your daily driver I suggest buying the built elocker thrid member from inchworm and either installing it yourself or taking the built thrird from inchowrm to you diff guy for install. You could also call Randy's Ring and Pinion or East Coast Gear and see if they can build a elocked third for you.
#25
#26
like I said if you can ship it I have a guy locally that can set it up for 175.00 plus parts. From what i read on ZUKs site shippings roughly 60 each way so your looking at around 6-700 total, he does good work. if you want i can give you his number.
#27
yea thats what the web site says, I have a friend locally that can do it. he worked for a place here locally that did nothing but diffs and axles so he knows his stuff. that price is if it needs gears, if not then it would be more like 5-600 total.
#29
Oh gotcha, good to know.
#30
Yes, I finally got it taken care of. $522 out the door for the labor, tax and an axel seal. That was a discounted price becasue of the trouble. They wanted $700 at first.
No, the process was not plesent. I was pissed. They had my truck for 10 days total and I was not prepared to let them have it for more than one day. The story changed every day. I know they have been in the diff business for 30 years so...and they said they had experiance with Toyotas.
The issue was they didn't want to use the R&P that was in my truck. It had a slight "herringbone" pattern they were concerned about. In the end, I made them use it and it was fine. It's not a cadillac, right. The fact they did'nt just reuse the OE R&P on the first day casued all the problems. I've had it about 6 weeks and 1,500 miles and so far, so good. Feels tight, no leaks but my fingers are still crossed.
Love the TrueTrac!
It would have been better if I just bought a built thrid off the internet. It would have all new parts. The only new parts in mine are the bearings. The TT was used. So I got burned, but live and learn.
Total cost for me was $1295 including the RP I didn't need, rental cars, overnight shipping, extra pinion nut ect. Not a total waste of money but for the same I could have had all new parts.
#31
This, in particular, is why I think the OP should order a all new third online. if the diff housing is rotten he needs a new one. Hope the axle housing is ok!
#32
Hey all, so I talked to a few guys around my area.. Turns out it wasn't my diff that was rusted out, its the axle housing. Local guy in town thinks its just the bearings that need to be replaced and said he could do it for $800... but now the axle housing is leaking pretty bad so I've got to replace that I think. Anyone know any places where I can purchase one? Found a couple online, $1200 and $900...
http://www.automotix.net/usedautopar...a61&seq_num=75
I think that one comes with the diff.
And then this place too..
http://www.toyotapartsales.com/partl...layCatalogid=0
Anyways, any thoughts?
#33
Just found this on ebay...
http://cgi.ebay.com/ebaymotors/96-99...ff6e#vi-ilComp
Says it will fit makes and models w/ these options...
TACOMA 00-02 4x4, w/diff lock, w/ABS, 4.10 ratio (6 cyl)
The thing is I don't think that my truck has ABS.. but everything else is the right fit. Is ABS a deal breaker?
And if I buy this one on ebay then I do still need to buy that kit from Inchworm?
#34
i would check out the local wrecking yards for the housing. the bearing change should only be 200-300 not 800. i didnt even pay that for a regear. get a housing used from a wrecking yard and then take the diff and have a new setup kit put in. at the most with the cost of the kit which is 250 from marlin it should be about 450-500
#35
What is the address for marlin? And what about inchworm that was suggested earlier..
http://www.inchwormgear.com/store/pr...oducts_id=1134
That one is only $185. That's what I am looking for, correct?
#37
yes on the setup kit. thats a good deal for 185. on the housing i think i would try and find something locally at the wreckers. I think my buddy found one with the elocker diff for not much more than 450. make sure the housing that you get is for a elocker. if nothing local then the ebay would do as long as its elocker rear.
#38
As far as the axle assemblies, you need to be sure you get the right suspension setup. Tacoma's have leaf springs, and 4runners have coil springs. I don't see you mention which you have, but you can't put a taco housing on a 4runner, or the other way around without some serious welding (and make sure the diff ratio is the same or course).
Those e-bay axle assemblies are in Canada. I have a feeling that the $200 shipping is within Canada only. I shipped an axle assembly and I couldn't find shipping within the US for $200, let alone across the border. That seems very suspicious to me.
#39
I'm trying to get a hold of the company to get some details on the assembly... there has to be some catch if they are selling it that cheap. They have another assembly that would work also and they want $600 for that one. I'm contemplating just buying that rear on autotmix ( http://www.automotix.net/usedautopar...a61&seq_num=75 ) for $1200 and just call it a day....
