Performance Product 1" Lift Springs are Discontinued
... just called to place an order, looks like they discontinued these springs.
Any ideas where I may be able to pick up a new set? Not sure if any other online vendors would carry these springs or keep them in stock?
Thanks...
-batsoff
Thanks...
-batsoff
depending on your year, 99 springs will do just as much as the PP springs. Sonoran Steel also has a kit that uses the 99 coils. OME is another option. I went with the 881/906 combo and i am pleased.
Thanks Gilby...
What shock are you running... your sig doesn't say?
The 99 coils are an option... would prefer to run something other than stock coils, maybe the TRD progressive coil up front. No idea what I'm going to do with the rears.
Seems like my options are pretty slim at this point, OEM or OME...
i'm pissed... just spent the last 3 weeks looking at springs/coils and I'm back to square 1.
I need a coil that matches up well with the Bilstein 2450/51 combo.
-batsoff
-batsoff
Gilby,
I was looking at your sig and noticed that you are running the Brembo/Hawk brakes combo and I was wondering how that's holding up? I am getting the same setup since my rotors are stock and I have 141K on my rig. Soon after that, I will be running the same suspension setup as you, the 881/906 combo with the both front and rear comfort shocks. Did you notice any rake or is barely noticeable?
There is a noticable rake at first. I like the look of the rake. Once i put my tools and what not in the back i dont even notice it. As far as the brakes are concerned i can tell a difference over the OEM set up. I am pleased with the combo.
I was afraid this would happen when I found out Performance Products was purchased by 4WheelParts.com. 1 less choice in the world.
Paul
Paul
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
