optimum shifting points or 22re...
Old 02-02-2005, 03:00 PM
Glenn's Avatar
Originally Posted by Five1Nine8Eight
If anyone is still interested.. I took my GPS to school today and on the way I found that my I am 10mph off. I have L235.75x15 BFG A/T, I measured them and they are 28" tall.
On the speedometer it says 20mph and the GPS says 29.8, and at 50mph in the truck the GPS read 60-61. It was hard to keep the speed consistant because it was really windy.
BTW, I have a 1994 2WD P/U 22RE.
I also started shifting at 3500-4000 today to try it out, I didn't know that lil engine had the power!
Your speedometer is off so much because your tire size is way larger than stock. My old 2wd came with 205/75-14 tires.
Old 02-02-2005, 03:03 PM
boogyman's Avatar
Talking
I have a tach on my truck and rarely use it (although I'm always right around 3000 rpm when i ˟˟˟˟). Listen to the engine. If you've driven enough stick shifts, you should know when to shift just by the sound.
Old 02-02-2005, 03:33 PM
88yotaboy's Avatar
2nd 15-20
3rd 35
4th 45
5th 60
Old 02-02-2005, 06:44 PM
89macrunner's Avatar
sounds is always the best way to go because guages are not always accurate..unless of course you like to listen to loud music while ur driving ..haha since i got my new clutch ive been screwing up all the time because im so used to where it used to catch and i cant hear the engine or feel it because of my sub..lol i have to go back to driving with no music till i get a feel for the new clutch
Old 02-02-2005, 07:13 PM
  #25
88yotaboy's Avatar
ya loud music kinda makes it a guessing game when you dont have a tach.
Old 02-02-2005, 08:07 PM
  #26
Glenn's Avatar
Just rest your hand on the shifter and you can feel the RPM's. Sorta.
Old 02-02-2005, 10:03 PM
  #27
Five1Nine8Eight's Avatar
Thats what I figured. Im going to get 31" tires next time around. Is it going to be off even more, like 13-14mph? Is there any way to correct the the speedometer?
Old 02-03-2005, 09:28 AM
  #28
Glenn's Avatar
Yes, it will be off by even more. You might be able to fix this with an adapter from Tacoma Speedometer & Instrument. I corrected my speedometer with one of their adapters, however your truck may not have a mechanical speedometer cable like mine. It might have an electronic connection.
Old 02-03-2005, 10:25 AM
  #29
phorunninduke's Avatar
I dunno, for me it was really hard to get used to it. Comming from small block engines, the sound of a 4cyl getting higher rpms sounds soo wrong. But the 22re really seems to like 2500-4000 rpm. I also know for a fact that you get better gas milage at about 3000-3500 rpm, at 2000ish you just dumping gas and going nowhere.
You can get a simple tach for about $30 at almost any auto parts store, like this one . They are real easy to install, one ground, one for a light, and one to read the rpms. There are several places you can tap into but There is an extra connection in a terminal you can plug it right into on your truck. Cant recall which one at the momemnt, but someone else will.
Old 02-03-2005, 10:29 AM
  #30
this is for his 85 so its definatly mechanical.
I have had my speedo cable disconnected for a while because it was squeeking alot, when I replace it I will have to get one of those adaptors for sure. Mind me asking howmuch $$$ becuase it dosent say on their site.
Old 02-03-2005, 10:38 AM
  #31
PoBoy's Avatar
I cant beleive some of ya'lls rpms! I usually shift at 2500 rpms. Anything more and it "sounds soo wrong" - SO LOUD. Unless in 4th or 5th, my 22re likes 1700-2500 rpms. I shift relying on "sound", but after driving my old jeep which shifts were 2k-3.5k...I took notice of my rpms and speeds.
My owner's manual says the following:
2nd 15mph
3rd 25mph
4th 40mph
5th 45mph
This is pretty accurate to my shift speeds. I shift to 2nd closer to 10mph though and 5th at 50mph.
Old 02-03-2005, 12:39 PM
  #32
Glenn's Avatar
I can't remember exactly. $50? Call and ask.
Liadrin
04-25-2022 02:54 PM
Liadrin
09-01-2015 06:44 AM
JAmdor3
08-11-2015 10:53 AM
v_man
07-23-2015 04:01 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: optimum shifting points or 22re...
