OME Leaaannnnnnnnnnnnnnnnn -
Old 03-02-2005, 08:57 AM
GodwinAustin's Avatar
For those of you with OLD MAN EMUuuuuuu suspension - how much lean did you have up FRONT after installing your coils and having them settle?
Were you falling out your friggin window? or was it barely noticeable? did coffee fly from the allready unusable cup holders in gallons instead of liters?
basically I need to know if it is even neccesary to add an extra trim packer to my taco since it would be a huge PIA to do it 12 months down the road after the install.
peace out brothaz !
Old 03-02-2005, 09:22 AM
payyourtoll's Avatar
My fronts had about 3.5" inches of lift for the first week, then 3", and finally settled to ~2.5". Up front I have ome 881, n91, 1 set of trimpackers, AND 3/8" revtek topouts and studs.
Your bumper will make the suspension settle even lower, so my vote is yes, add the packers.
Old 03-02-2005, 09:44 AM
ok - I was definetly going to add one set to each side for extra lift...
BUT should I add an extra TP to the drivers side to counteract the extra weight on that side? or does the drivers side not lean THAT much - and subsequently is not worth adding the extra trimpacker to the DS?
Old 03-02-2005, 09:55 AM
no way would I add spacers unless they were evenly distributed to both sides. Front to back, fine. Side to side I would re-consider.
Mine sits purrrrfectly level:
Old 03-02-2005, 10:00 AM
TDiddy's Avatar
I'm not really sure if lean is something you can predict. I know I couldn't, and had to take the front DS off to add some.
Old 03-02-2005, 10:06 AM
HOJU's Avatar
mine's level, haven't had any issues with "leaning"
Old 03-02-2005, 11:49 AM
cool - I really appreciate these replies - as some people have suggested the need for additional trim packers - really 1 additional - on the DS as supposedly Tacos are heavier on that side - who knows...I would assume 4runners would be the same way
But really I didnt want to put an extra trim packer on the DS unless I really had to - you know, if the lean would be ridculous -like a .5" or something
Old 03-02-2005, 11:56 AM
superduper's Avatar
I have practically the same ome's as everyone (shocks/coils all around) but for some mysterious reason I did not get even a 1/4" of lift up front while the rear lifted about 3". I had to add some Cornfed spacers to level it out.
Old 03-02-2005, 12:16 PM
well from what I read F/R lean is standard as the rear 4runner OME coils are longer than the fronts and give quite abit more lift -
L/R lean is what I am worried about.
Old 03-02-2005, 01:00 PM
96LtdYota's Avatar
thats why the drivers side coils are about 5 mm taller than the passenger, duh
Old 03-02-2005, 03:05 PM
I thought the DS and PS OME coils were the same height and hence the Trim packer?
Old 03-02-2005, 03:12 PM
HOJU's Avatar
remember that the coils we use for the 4runner are actually designed for the Prado, it's long lost brother. The drivers side coil is longer to compinsate for a little bit extra weight on that side. if you put the coils in on the wrong side, then that might explain your "lean".....
Old 03-02-2005, 07:20 PM
TDiddy's Avatar
The rear coils are obviously different lengths, never noticed much difference on the fronts though. We did give the fronts a good look and did pick the one that looked slightly taller for the DS.
Old 03-02-2005, 09:24 PM
Stegall984R's Avatar
Location: OmG, Hi2U !!! .... DANG, my chic's got some SEXY eyes.... among other things. WOOT WOOT !!
ive got some rear lean...
the passanger side is about a inch lower then the driver side. Any ideas ??
Old 03-03-2005, 05:14 AM
yeah - Allen - add one of the 10mm OME rear trimpackers - I think xtreme off road carries them.
you will have to take the coil assembly apart though
Old 03-03-2005, 05:17 AM
yeah - I was looking at the two front coils and I really cant see a discernable difference in height - ahhh well....
it would be nice, if OME did make the coils different sizes, they would mark them that way....I mean they must mark them somehow if one coil is taller than the other right?
Old 03-03-2005, 05:27 AM
HOJU's Avatar
my coils had little stickers on them, marked with what side they needed to go on...
Old 03-03-2005, 06:04 AM
mine to.
Old 03-03-2005, 06:07 AM
what the - something that said DS, PS - or soemthing like that?
Old 03-03-2005, 06:28 AM
TDiddy's Avatar
Don't worry about the stickers, most of the time they're labeled for the Prado anyway, which means you have to go opposite of what the stickers say. Just go by height.
Quick Reply: OME Leaaannnnnnnnnnnnnnnnn -
