OME 3rd Gen What to buy Where to buy
Old 01-06-2006, 03:31 PM
xcmountain80's Avatar
Good evening kids I need some advice again, I have a 2002 Runner Tow almost everyday for work and when not towing I have my mountain bike gear and camping gear or tools or whatever in the back. I have plans for a Aonoran steel rear bumper as well as a ARB or TJM up front Winch you ask but of course, and what good rig would be without sliders. Soooo as the title says where to buy and what
Option one
SleeOffroad $675
RockyRoadOutfitters $617
TRDParts ?
HeavyDuty
OME881 heavyduty 2
OME891 Expedition 2
OME95PF5 Front 5mm coil spacer 2
OMEN86 Medium 2
OMEN91S Medium 2
or LightDuty
OME882 2
OME890 2
OMEN86 Medium 2
OMEN91S Medium 2
Thanks Aaron
Yes I think the choice is evidentand I will need the Heavy Kit
Also for a lift this minor will Extended brake lines be required? or a replacement Panhard trac bar and bracket? What about a differential drop spacer as well? hope to hear from you soon.
Old 01-06-2006, 03:33 PM
Localmotion's Avatar
scrap all of that and search for the TUNDRA/OME Lift
there is enough reading to keep you occupied for a couple of hours
if you are always towing..maybe a tranny cooler ...
and a supercharger..LOL
Old 01-06-2006, 03:39 PM
Ive have read about this but how does it compare performance? Cost difference? I kinda hit a dead end before when I started researching the tundra coil lift maybe I didnt look hard enough. I already have a tranny cooler not in the market for the Super charger though I did see a Lexuse IS300 with the 3.4 and 950HP that would be a good swap ..
Thanks
Old 01-06-2006, 03:43 PM
garrett1478's Avatar
https://www.yotatech.com/forums/show...&postcount=629
plug all these part numbers into www.toyotapartsales.com and order away
Old 01-06-2006, 03:46 PM
Thanks
the performance/ride is unbeatable. I think the cost is almost the same, maybe a +- a couple of bucks. The performance is proven over and over and over and over...LOL
http://www.4rnr.net/ the creator
https://www.yotatech.com/forums/show...t=tundra+coils prices
Old 01-06-2006, 04:25 PM
Yea the price really isnt my primary concern reliability and performace are the key. Hmm cool enough so that takes care of the front end so the rear end just do OME like I planned or is there some trick system for that as well will there be anything additional for the rear? Spacer what not?
Aaron
go with the OME 891
Old 01-06-2006, 07:49 PM
jodynich's Avatar
or downey hd coils
Old 01-07-2006, 02:38 PM
Originally Posted by garrett1478
Ok this sounds good too but none of the items in this link are OME so do I
A. nix the OME and use the factory parts listed
B. Use the OME struts and OE toyota stuff
C. scratch my ass drink 4 car bombs and then attempt to order
by the way I know what the OME lift looks like anyone have pics of thier Full toyota lift? If its on Sonoran Steel I've seen it. But there still lingers the other question about the Extended brake lines the panhard bar/ bracket and the diff drop spacers?
Aaron
Old 01-07-2006, 09:51 PM
Mr. Bob's Avatar
Here is exactly what you want to do the OEM/OME lift
Toyota coils:
LF coil: 48131-AF100 ( Tundra )
RF coil: 48131-AF090 ( Tundra )
LR coil: 48131-6A570 ( 7 coil FJ80 )
RR coil: 48131-6A480 ( 7 coil FJ80 )
Front:
OME N91S struts
3/8 top up spacer(s) and longer studs- one possibly 2
1" front diff drop
Rear:
OME N86 shocks
Drop panhard bar
Hope that list is what you were looking for
Bob
Old 01-07-2006, 10:37 PM
Aaron
i suggest either option A or B....
Option A is layed out in the link i gave you, Option B is what Mr. Bob wrote above...its your call either way, they're both excellent setups.
Old 01-08-2006, 01:07 PM
4RUNN!N's Avatar
Toyota coils:
Front:
OME N91S struts
1" front diff drop
Rear:
OME N86 shocks
Drop panhard bar
Bob
With that setup, how much does it lift the front and rear? Ride quality? rear sag?
Old 01-08-2006, 02:16 PM
Mr. Bob's Avatar
Those LC front springs in the rear of a 3rd gen runner give anywhere between 2.5" -3"s of lift, depending pn rear bumper and rear cargo ect...
Those tundra springs net 1.5" - 2" and then using 1 or 2 - 3/8" top up spacers make up for the rest...
Ride quality from what I understand is identical to stock... and if you get a used set of LC spring measuring 19" - 19.5" there will not be any sag, as the springs will have already settled...
Hope this helps... I have mine on order, will be here this week... when I get them installed I can give a full report!!!
Cheers
Bob
Old 01-08-2006, 02:39 PM
FilthyRich's Avatar
this is my 99 with Tundra up front w/ 2 spacers, OME in the rear with 1" BL and 285 MT/Rs:
Old 01-08-2006, 02:47 PM
Mr. Bob's Avatar
Eric... that is the frist time I have seen pics of your truck ( Im new here ) and crap does it look nice... exelent exelent work!!!
Old 01-08-2006, 02:49 PM
FilthyRich's Avatar
I have several photo whoring threads. Search under my name and you can find my rear bumper build too. Oh and this spring the truck becomes monochromatic
Old 01-08-2006, 02:52 PM
nice! that's gonna look sweet!
Old 01-08-2006, 04:24 PM
4unner4life's Avatar
you probably will not want to use the LC coils for the rear if you tow every Day. They are a little to soft if you do alot of towing. Check out the LC coil thread i believe someone towed with these coils and changed back to OME. But definalty go with tundra setup for the front.
Old 01-08-2006, 06:03 PM
I tow a 5x12 encosed trailer tongue weight maybe 150- 250 lbs. or a open 6x12 open w/air compressor a quad and tools tongue weight hmmm 200-300 lbs.
Aaron
Old 01-09-2006, 04:59 AM
FilthyRich's Avatar
Aaron
I tow my 5'x8' utility trailer a lot, plus motorcycles and the occasional car. I have the OME coils in the rear and have not had any issues with sag. My vote is for the Tundra setup in front w/ spacers, OME shocks all around with OME coils in the rear
Quick Reply: OME 3rd Gen What to buy Where to buy
