Old Man Emu or Sonoran Steel?
Old 03-20-2009, 01:44 PM
yotarunner24's Avatar
HELLO. i'm new to yotatech, and i was wondering if anyone has some feed back on the OME 2.5" lift and/or the kits offered through sonoran steel
Old 03-20-2009, 02:07 PM
Bighead's Avatar
You might want to do a search on both and read the info on the Sonoran Steel lift page...lots of info there.
Old 03-20-2009, 02:12 PM
Squiddy's Avatar
I did OME and love it
Old 03-20-2009, 02:17 PM
JuJew's Avatar
I did the OME lift with Bilstiens and I love it!!!
However, after reading Steve's web page: Sonroansteel.com I might have gone with one of his kits. His research is thorough and well documented. He has had the luxury to run several different setups and has put together some great pacakges
Old 03-20-2009, 02:35 PM
squiddy, did you get the 2.5" kit from rocky-road? did you have to do any other mods?
Old 03-20-2009, 02:54 PM
Roland4x4's Avatar
After a few month of investigation, I get the SonoranSteel lift kit.
Old 03-20-2009, 04:58 PM
what sold you on the sonoransteel?
Old 03-20-2009, 05:05 PM
GSGALLANT's Avatar
All Toyota components (and Bilstein) sold me on Sonoran Steel. And their customer service is awesome.
OME kits work well to help you carry more weight... they are not truly designed as a lift kit. You will get a better ride overall with the SS kits.
Old 03-20-2009, 06:35 PM
Vermejo's Avatar
Sonoran Steel hands down.
Tried and true, still working like new after thousands of miles spent on the dirt
Old 03-20-2009, 06:41 PM
waskillywabbit's Avatar
I've installed both and ridden in vehicles with both. They both perform very well.
It really depends on the ride you want and what you are accustomed to currently, what you are looking to do with the vehicle, budget, personal preference, etc.
You won't go wrong with either setup.
Old 03-20-2009, 06:53 PM
Mulkey's Avatar
OME just uses longer springs and shocks just like some SS kits. They lift 3.0- 3.5 inches in the back over stock just like some of the SS kits. Obviously some of the SS kits are geared more for offroad like the 1.2 lift but some are not. Depends on how much you want to spend and what use you're looking for.
Old 03-20-2009, 07:00 PM
84RNR's Avatar
I've had OME lift on a previously owned truck and loved it. Would go OME again and may soon on my '03 Taco.
Old 03-21-2009, 05:35 AM
Bighead's Avatar
I have been a Sonoran Steel guy for a long time and have not regretted it once. I have used OME also and found the Sonoran Steel system (1.2 in my case) to be better for my needs...both on and off-road.
Old 03-21-2009, 07:39 AM
JuJew's Avatar
Ask for opinions and opinions you will get!!!! You can tell everyone here is passionate about their rides.
I don't think you will be disappointed with either setup!
Old 03-21-2009, 07:48 AM
crolison's Avatar
I pieced my lift together......
I wanted adjustables up front, and fj80 springs were too high for 33's, but i carry a lot of weight. So i went with 891's with 5125's. I have some used fj80 coils to slap in when i swap it to get another inch or so.
Old 03-21-2009, 08:18 AM
X-AWDriver's Avatar
The OME is more budget minded and is fine for most off roading duties but the Sonoran kits are sweet. The OME kit can be had for a little over $700.
Old 03-21-2009, 09:17 AM
wow. lots of good info. i guess for my rig i'm just lookin for a little more clearance than stock. i've geared up 3 different wranglers, but i've never done any yotas. my budget is geared more towards OME but after reading the comments on the SS website i'm a little nervous about shocks breaking and having to spend more money in the long run. I don't hit the trails as much as i used to (maybe 4-5 times a year) and i don't want to overkill with the SS @ $1,200.
Old 03-21-2009, 09:20 AM
i'm also worried about having to additional mods. the people i have spoken to at OME say that their 2.5" kit is designed to replace the stock shocks and coils without having to do ANY other mods to my rig. Has anyone found out the hard way that that isn't necessarily true?
Old 03-21-2009, 09:47 AM
crolison's Avatar
The front you don't need any more mods, the rear all the mods I did were extended brake line, and unbolted my parking brake cable holder.
But i am running 3-3.5" of lift in the rear. With the 2.5 I wouldn't worry about the rear mods.
Old 03-21-2009, 10:00 AM
Skrillah's Avatar
Yeah, the SS kits are really sweet but my budget can't allow for something like that. They are a nice system indeed and do use an OME 890 spring for one of the kits.
If you decided to stick to "piecing it together"...then a Bilstein or OME shock shouldnt' fail you. They are good shocks and offer great warranties.
The only other modification you should make would be a front differential drop to accomodate the added angle to the CV. The rule of thumb is generally any lift over an inch should have this installed. Otherwise...depending on your use...replacing CVs will be common.
Quick Reply: Old Man Emu or Sonoran Steel?
